4spd to 5spd Swap
Old 12-08-2004 | 11:42 PM
Topgrump's Avatar
Topgrump
4spd to 5spd Swap
I have an 85 F250 4WD with a 460, Bw T-19 and 1345 Transfer case. I interested in swapping in a zf 5spd to replace the 4spd as it is making a lot of noise. What is involved in this swap?
Old 12-09-2004 | 02:37 AM
mustange70's Avatar
mustange70
Should be a bolt in swap since you should already have the hydro clutch, but i would grab the crossmember and driveshaft (if its the same cad config.) and swap everything in, just be sure to get one from a 4x4.
Old 12-09-2004 | 08:11 AM
bremen242's Avatar
bremen242
You'll have to figure out the slave, ZFs have concentric slaves, whereas the 4spds are external.
Old 12-09-2004 | 01:08 PM
Bruce P's Avatar
Bruce P
Tranny Swap
I am in the process of replacing/rebuilding my T18 tranny and it was mentioned the ZF five speed would work. (1986 F150 4x4 with 302)
Well yes the bell housing bolts right up. An that's it.
I would love a five speed overdrive BUT, as mentioned previously, you need the crossmember support, shorter drive shaft and a change around to the slave valve for the clutch.
I looked into the cost (used) of all these parts and just the cost of my rebuilt T18 was cheaper than all these parts. Plus I still had to buy a rebuilt ZF five speed (hens's teeth to find up here) but I found one $2100 Cdn. Total cost for the upgrade was $3,320 and I had to install it myself.
Rebuilt the T18 was $410
Guess which one I am doing. The T18 is on the floor right now ready to go in.
Bruce P.
