Beating The Idle Topic Like A Dead Horse!
#106
my truck is throwing a code 13. cannot control low RPM idle or something like that.
i readjusted the idle set screw to .97 volts and the IAC was alternating between 11.47 to 9.61 Volts which should average to around 10.5 Volts. so i know those 2 are still within spec.
manifold vacuum holds at around 15 in/Hg.
idles at 850 rpms.
and the dwell is 22.6 degrees for an 8 cylinder. i have no idea what this is or what it's supposed to be at to be within specs. i'm not able to measure frequency.
idles at 850 rpms.
#107
#109
#110
you know, i do notice that the springs don't really pull the plates closed all the way. whenever the truck is idling (steady that is...) i am able to change idle (lower it) by pushing on the lever on top of the TB more closed.....does that mean the spring is bad or the plates being stuck?
also the voltage reading of the TPS doesn't readily go back to where i adjusted it previously, only until i push on the TB lever...
#111
I am not exactly sure when at some point I had replaced the throttle cable from the gas pedal to the throttle body also. There also may be some binding there also that the srings cannot overcome.If there is a lot of carbon around the plates the air can slip through also.As these trucks get old it can be an accumulation of a few small things that cause the problem .It sounds like you have narrowed it down.Try by process of elimination.If you remove the throttle cable from the throttle body see whats happens. Does it snap shut? Try to narrow it down before you start spending money.
#112
I set the TPS to .93 volts at idle and it gives me 4.63 volts at WOT. Runs smoother now. I removed the EGR and pluged the hole on the intake, made no difference on idle speed.
I checked and rechecked all the sensors and connections. I cannot find the source of the hanging and high idle.
Can the aftermarket TPS be the problem? Do I need to get a Ford TPS from the dealer?
If all else fails, I will bring it to a shop with a full diagnostic machine.
Ed
Ed
Yes it's an old thread, but relevant.
#113
The fluctuating idle issue....
Hey guys this is the best forum i have found yet!!!! Ty
Ok...1989 f250, 351w, autotrans?..
Bought truk 2 yrs ago, drove 400 miles home, then used it on ranch as needed....no hiway use till now...
When i got it running again properly i had similar issues u all have mentioned...
I was chking visually every hose in engine compartment an when i tooj my hand off the vacuum cluster near distributor it was covered in black powder...
Realized this was from vac lines....
Bought new vacuum lines an replaced all of them with rubber....
Wah la!!!! Idle issues gone, truk previously was hard starting, now 2 cranks an she fires right up!!!
That took care of a lot of issues...heater weak, hard starting, trans shifting....
Just thot id put this fix in as info...
The issue i have now is when at 55mph the engine shiuld b 1800 rpms...its 2500 rpms...cant seem to get it resovled yet...
Any ideas?
Ghiaguy
Any ideas?
Ghiaguy
BocceMon
05-09-2017 12:33 AM
LGS
1997-2006 Expedition & Navigator
09-24-2016 09:08 AM
