that is not true. while most hiboys have divorced transfer cases, trucks ordered with full time 4 wheel drive got mated transfer cases. a supercab is automatically not a highboy as they were not available until after the frame change in mid 77. the hiboy got its nickname due to the frame design which was different than regular trucks and was discontinued part way through the 77 model year. the hiboys can easily be identified by the ladder frame design which is a few inches narrower than other ford trucks. this means that many components that bolt to the frame are different. the most obvious is the bed as the mounting bolts are closer together. hawkrod
roger that ,just modified my 77 frame for a 79 box
just dropped the 77 off at the body shop today , the boyz there were amazed at the lack of rust, hiboy resurection. was this thread dead for a while ? I m new on this thing learnin' stuff. she s a 400 stick shift.wonderin about a 460 swap . I ve got a 77 2wd with 460 what doya think thx
