Fumoto oil drain valve
Looking at getting stuff for the new truck, can someone take a picture of pan under the engine specifically showing oil drain plug, Fumoto site indicates an adapter fitting might be necessary for this application. I typically like to change engine oil at around 1500 miles on first change, and install a Fumoto oil drain valve at that time. Driving from Iowa to Texas most of the 1500 miles will already be done.
Also looking at swapping in Warn or Mile Marker manual hubs, Husky liners, basic stuff to get truck set up where I want it. Hopefully last truck I will buy. Also prolly change rear diff oil at 15000 miles. Any other maintenance related suggestions? 7.3 gas engine, F350 Lariat Tremor Sport CCSB.
The following users liked this post:
I tried the Fumoto valve. It is easy and can be easier to capture the oil, however its way to slow for me. Draining 13 quarts with a small valve body takes a while. I want to get under my truck once. Drain, change filter then out. I'd fall asleep waiting on the oil to fully drain.
I like my Fumoto, as I can easily drain into the empty jugs from the previous oil change, using a short neoprene hose (mine has the 90-degree elbow). The valve allows me to easily shut off the flow when a jug is full, then allows another jug to be placed and filled cleanly. I just throw the filled jugs back into the three-jug box and keep the empties for next change.
As the last jug is being filled I place a low-profile 20-qt bucket under the oil filter (so that it clears the support arm and directly under the filter), and loosen the oil filter enough to let it trickle into the tub. When both the drain plug and oil filter start dripping I close the valve and bag up the old filter. Fill the filter with fresh oil and install, and I'm done underneath.
I reckon it's a matter of convenience for some, but a slowdown for others that might want to get the job done quickly. I tend not to rush things, so the Fumoto works out fine for my needs.
The following 3 users liked this post by JoeUser:
https://talonsgarage.com/collections/ford-f-250
My shield is one of the early prototype units and did not originally include an access panel for the oil filter. So I made my own access ...
Love my Fumoto. No more mess. No more worrying about drain bolt washers, threads, etc. I open it up and let it drain and do other things while it's draining (check air filter, change oil filter, check tires, get my new oil jugs ready, etc.) No adapter was needed on mine. I bought the version with the short nipple so I can attach the drain tube if I choose.
Same here. I started using a Fumoto valve when I installed a Talon's cat-shield. No adapter needed and slow draining doesn't bother me ... retired and not in a hurry.
https://www.fumotousa.com/f107sx.html
You may be able to get by with their adapter ...
https://help.fumotousa.com/en-US/Kno..._Fumoto_valve/
https://www.fumotousa.com/all-produc...h-f107sx-.html
There's an EZ oil drain value on Amazon that comes with a 90 degree elbow. That's the one I use now, had it on my 2017 too. It drains straight down with the elbow on. I pull the elbow off when I'm not draining the oil - I'm afraid I'll hit something and damage it. But it works perfectly - and always has.
The following 2 users liked this post by acdii:
