Did I Fry My PCM?
Did I Fry My PCM?
Hey guys... not proud of this one but here goes.
I was doing some re-wiring on my truck fuel pump harness this weekend. I may have also been enjoying too many cold ones while re-wiring. I may have not been paying that much attention to the wiring diagram... And I may have wired power to ground and ground to power by accident...
Anyways, now my PCM relay is clicking at the rate of a machine gun anytime I turn the key on, for some reason the left turn signal bulb is also illuminated. The only thing that fixes it is if I disconnect the tank selector switch. The fuel pump won't prime. I also checked the ground near the battery, it's good.
Am I cooked? PCM done for? Or possibly just fried the relay like a catfish? Anyway I can test it to see if it is ok? I appreciate the help! I'm adding "wiring" to my list of "shall not do while inebriated."
Here's a diagram for reference. Ignore the green circle. Truck is a 1997 F-350 5.8L CCLB 4x4 E4OD
I have a '97 F-SuperDuty, which is similar to yours, your truck should be made in Mexico? My F-SuperDuty is similar to an F-450.
theres a YouTube video of a guy that made a test box, works well, not 100%,
my guess is you’ve fried some wires, that are shorted together now, possibly damage to other components, relays, EEC, etc.
how long was power turned on when you reversed pos/neg?
The following users liked this post:
if you have the EEC wiring diagram, you can connect power, ground, fuel pump relay, STI, CEL on the bench. After turning it on, fuel pump runs for 3 seconds then turns offf. Connect the STI and CEL and you should get blink codes.
You have a short
Melted together wiring somewhere
The problems are too unrelated to be anything but a short IMO
See if it will output codes is how you check your processor
It will output 11-10-11 if everything is "A" Okay
Never a bad idea to check the processor diode
If you reversed pos and neg at the battery with the key on, you will have fried a fuse link or two
Start there, pull on those yellow fuse link wires and see if any are elastic like a rubber band
Those will be the no good ones, with the burnt fuse link wire inside
That and the @manicmechanic007 helped me in the past...
