Disconnecting Fuel Filter Line Help
Old 09-16-2024 | 09:42 PM
wannabuyaford's Avatar
wannabuyaford
96 F250 5.8 e40d
Like everything else on this thing, a simple job has turned into a multi-day project. I'm just trying to change the fuel filter. I have the Motorcraft replacement ready, I bought a metal multi-size disconnect tool. I removed that huge bracket. I soaked the connectors in PB Blaster.
The smallest part of the connector is the only one that fits in, so I tried it... and tried it. All I managed to do was mangle the tool.
Any tips/tricks/tool recommendations?
BTW I'm pretty sure it's the original filter on there.
Old 09-16-2024 | 09:51 PM
Junktownbill99's Avatar
Junktownbill99
What bracket? There are two plastic clips holding the fuel lines on the filter. No tool necessary.
Edit: nevermind
Old 09-16-2024 | 10:36 PM
Soup bean's Avatar
Soup bean
This thread has graphics and directions. https://www.fullsizebronco.com/threa...-lines.509347/
This is the same type of connector used on propane tank locks.
The spring steel tabs are blocking the raised part of the fuel filter nipple. Pressing the fuel line and the filter together is the first step.
The following users liked this post:
Old 09-16-2024 | 10:37 PM
Soup bean's Avatar
Soup bean
The plastic clips weren't used after 1991.
Old 09-17-2024 | 05:30 PM
wannabuyaford
Hm, still no luck. I've been at this for a total of about three hours if you add it all up. I see those instructions. There's no "play" in pushing it together, I wonder if that makes any difference.
Anyway, I appreciate the info so far but I'm still looking for tips and tricks if you have any.
My best guess is that the tool isn't long enough. Story of my life.
Old 09-17-2024 | 09:18 PM
wannabuyaford
I got this done. The whole problem was that my tool was too short. Borrowed one and it came right off. Who knew there was a difference?
Asim Khan
02-19-2016 09:04 AM
ajordan193
Modular V10 (6.8l)
06-27-2008 01:30 PM
jb8897
1983 - 2012 Ranger & B-Series
07-08-2006 02:18 AM
yup
03-19-2004 08:52 PM
TheNomad
1978 - 1996 Big Bronco
04-24-2003 12:32 PM
Quick Reply: Disconnecting Fuel Filter Line Help
