How to tell if you have transmission codes?
So I am trying to resolve a hard shifting issue with my 97 F250, Seems to come and go at times and is most noticeable with heavier acceleration. I am planning on doing a full transmission fluid change here soon and am probably going to replace the neutral safety switch.as well to see it that helps. I have already replaced the rear end speed sensor as I had an ABS light and that resolved that, I keep seeing people talk about how you can have transmission codes but how do you know if these transmissions are throwing codes? Truck is a 1997 F250 7.3L Powerstroke with the E4OD transmission,
Not necessarily. There could be codes but they aren’t bad enough for the computer to turn on the light. As seen in other threads, MLPS could be going bad but will not trigger a code. What exactly is happening with the transmission?
Shifting hard but not all the time seems to trigger a hard shift more often when your on the throttle a bit more. Fluid level is good checked hot level and it's well over halfway into the hot hash lines but the fluid could probably use changed. I have read other threads that said fluid/filter change and the MLPS can cause this issue in the E4OD. Already changed the speed sensor due to an ABS light so that's new.
![](https://cimg4.ibsrv.net/gimg/www.ford-trucks.com-vbulletin/510x521/shifter_c0f2c0546f243820bc5d45ee3533a57e51141b52.png)
No codes here
This feature on your truck is positive confirmation that you have no transmission codes.
I am guilty of using the 'parts cannon' approach too, especially when it's one of those
'well it's either the VSS or the RABS, and the sensor's $15, or the module's $300'
sometimes you want to make the attempt without the commitment...
NAPA's top- line stuff tends to be anywhere from 'acceptable' to 'quite good'
and MotorCraft has been sending me things made in China for years, so the
gloss has gone off that onion... (a 351 water pump? really???)
t
I think we all use the shotgun method at least once in our lives. Without a doubt, it's really not a good method but we all come up with excuses to prove the method works. Kind of like buying a lottery ticket. The ones that win the big one will certainly say it was worth the $1. There are millions that say otherwise.
When I go down that path I tend to think of the part as a maintenance part. Parts that are replaced because it's time. We have 30+ year old trucks and many of the parts have been used for that length of time, so it's not always money wasted. Such as the coolant pump I replaced at 120k, front fuel pump at the same mileage, radiator at 125k, etc. I certainly do not know how long they would have lasted, but I also know, I don't want to do that job on the side of the road too.
No codes here
t
If it helps, I have had an intermittent harsh shifting problem in my E4OD since 2005. Ever since the shop rebuilt my transmission. I know it's not the transmission since I rebuilt a core transmission with everything changed out. The original transmission is sitting in the corner of my shop.
