2021 Explorer PCM to IAT Sensor Pinout Schematic
Anyone have the PCM to IAT (Intake Air Temp) sensor pinout schematic the can share? I recently picked up a 2021 Limited Explorer and it's throwing a P0113 Code. I put a new IAT sensor in from Napa, but it's still throwing the code. On my scan tool, it's showing IAT at -40° F, which is obviously wrong. Trying to figure out what is going on. Wasn't sure if I can check continuity between PCM Connector and IAT Sensor, it'd rule out broken wire in between. Or if how to check if the sensor(s) are good/bad? Maybe the replacment sensor is bad too? Not sure?
Any thoughts are apprecated!
Thanks!
Thanks!
havanaone
12-25-2006 11:38 PM
Private Citizen
03-21-2004 02:24 AM
