A?C blows cold then hot
Have a 04 F250 5.4l that the a. blows cold then hot. Over the winter I removed the condenser while doing some work. I put it back together with a new drier and orifice the system and put in 42oz of 134A. It was nice and cold then drove it the next day and it started off cold then went hot. Came home looked for leak as I have dye in it. It looked like the high side valve might have a slow leak. Replaced it clean any dye up evacuated it again and recharged it. Still the same issue. No leaks found and my pressures are good. When the truck turns off and the go an use it again it start off cold again. It does sometime get warm and the back to cld. What might the issue be??? Any help would be greatly apricated.
dayman53
2009 - 2014 F150
07-05-2023 12:17 PM
mstang1988
2017+ Super Duty
12-21-2022 09:39 PM
