Is a catch can on a 3.5 a real thing ?
The following users liked this post:
Add BMW to that mix, and others - anyone watch You Tuber "I Do Cars"? Most all his DI only tear downs are nasty on the backsides of the valves... I think Toyota, closely followed by Ford figured out to add back in the port injection (dual injection) to solve the: "no it's not a problem" thing... As I understand it: Ford was offering a "cleaning" service, until they started having to replace turbos 100 - 1000 miles after that service. We have a DI only Benz that we bought used. At the MB dealer we brought it to for service, the first couple of times they offered a BG Intake Cleaning service. And then stopped - they too were replacing turbos and their fix for a carboned up intake valve was to Replace the heads! $12K was what I was quoted for that, but there just aren't a lot of problems posted on the MB forums, so perhaps their oil control for the PCV is "better" than others...? They also were late followers to the dual port injection - likely for the same unmentioned reasons....
The older were helped by a 'weep hole' being drilled into the lowest point of the intercooler to help evacuate the crud.
Beachums
2015 - 2020 F150
15
02-25-2017 07:40 AM
DanielT28
15
05-01-2016 10:23 AM
96_F250_Deezal
15
02-02-2014 03:18 PM
73mach1
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
16
08-18-2005 09:04 AM
