LED Light bar install
I removed this thread..... My intent was to provide a detailed alternative mounting solution for forward auxiliary lighting -LED light bars. Instead, there were as many posts commenting on driver courtesy using their high beam headlights and light bars, as there were questions or comments about the install. Sorry
The following 6 users liked this post by jbrnigan:
The following users liked this post:
Back to the topic at hand: If you power the relay from an upfitter switch then you can easily disable the led bar when using the high beam harness as a trigger. I don't think that was understood when the last question was raised.
The following 2 users liked this post by jbrnigan:
Clean install and I'm thinking of copying your install approach. I'm looking for a slim single row 30" curved bar with a combo pattern. Hoping to tuck it in as far back on the mounting pad and as close to the grill as possible. Found a couple options so far (31.5 inches end to end). What 22" bar did you run with?
I drive 75K or more miles a year and every single night on the road I get accosted by people who have no courtesy about these things, and it creates a very dangerous situation.
You being a courteous driver is great, but there may be others reading this thread who don't give a thought to this situation, maybe my request will cause them to think about it and do the right thing.
queen of spades
18
04-24-2023 08:09 PM
