Anyone running a catch can on their 7.3
After changing boots on my 7.3 power stroke, I realize there has to be a better way to control oil entering the intake system via the CCV. I was thinking about adding a quality catch can to my list of projects this summer. Seems like there would be a way to use it as part of a "loop" system, as having the hose exit the ccv enter the can , depositing the excess oil, and then re-entering the intake. I've looked at a few homemade systems on google, but I really don't want to just drop a hose to the bottom of the chassis. Any thoughts?
Currently Running catch can and it’s not a perfect solution
Problem is that soooo much oil comes out of that dog house it now slobbers one the front of my battery :/ it saturated the breather filter in the first few days. I mean I ran about a yard of tubing before even getting to the catch can.
I don’t know what to do with this system. Perhaps running down to the frame would be fine. Willing to entertain discussion and try fixes suggested. But to be clear a hose going back to the intake will still let a lot of oil in it. I plugged up the breather return to the intake.
I think I agree with the others on put it back to stock and just wash the engine bay more often.
I planned to do the catch can years ago but always feared issues/ damage from them getting blocked up. towards the end of last year. I ran my line over the hydroboost and straight down to atmosphere. It can be messier than just dealing with sweating boots. So when the weather gets better; I will run it back into the factory intake piece.
another option some used to do was to put a bung into the exhaust and plumb the ccv to the bung and let it burn off through the exhaust....that might be the best solution besides the factory design
I've had riff raff boots on mine for probably 7 years now with stock clamps and don't get any oil seepage out of the boots. Sure there is oil on inside if you take one off but none of it seeps out like it will with factory boots.
I have a T444E draft tube I'll be selling if you want to vent to atmosphere*, but our trucks smell bad enough as it is and this sure wouldn't do it any favors.
*I see it mentioned a lot that this is "what International intended"... the engine was designed with Ford as the primary client in mind with "beyond pickup" duty as an additional application for other clients. Might as well say International never intended the engine to rev over 2,600 RPM.
The following users liked this post:
