Need Fender Trim Piece
Old 10-02-2023 | 04:57 PM
Skylaneman's Avatar
Skylaneman
I need to replace the trim piece that goes here, looks like the second photo. 2016 F150. Does anybody have a link to the part or a part number?
Old 10-02-2023 | 05:20 PM
SpencerPJ's Avatar
SpencerPJ
It's a fender flare. Here's one off fleabay that might work
Edit: sorry the one I linked was not for left rear, that seems what you need. Google fender flare, left rear, F150
Old 10-02-2023 | 06:27 PM
JKBrad's Avatar
JKBrad
When that happened to me, I found a set of 4 Magnetic Metallic ones on eBay and replaced all 4 black ones with grey ones.
If I had to do it again, I’d go with a set of Bushwhackers. I’d have just removed them, but Ford had to put a bunch of mounting holes around the wheel wells.
Old 10-03-2023 | 11:56 AM
Olds64's Avatar
Olds64
Here's a link to a supplier of those Bushwaker fender flares.
https://realtruck.com/c/exterior-acc.../f/bushwacker/
Not cheap, but probably comparable to a part. I wonder if you'd have to run oversized, knobby tires to make the truck look right with those Bushwakers?
Old 10-03-2023 | 01:15 PM
JKBrad's Avatar
JKBrad
They have the OE style flares, which are similar in look to the OEM fender trim. Flat black gies with every color. The only drawback is that they don’t use the holes in the factory body panels for mounting.
The following users liked this post:
Old 10-04-2023 | 05:54 PM
Skylaneman's Avatar
Skylaneman
I need a right rear.
Old 10-04-2023 | 06:00 PM
Skylaneman's Avatar
Skylaneman
I just removed a set of aftermarket flares due to the fact they are damaging the paint. The reason for this is they only attach from the underside. This allows the top part, the part you look at, to move slightly. All four fenders have areas where the flare has rubbed thru the paint. My body shop guy said looks like they were painted with a rattle
can.
Old 10-05-2023 | 09:32 AM
Olds64's Avatar
Olds64
^^^THIS^^^
I'd think you'd have to drill holes in the fender to secure the fender flares properly. Double sided foam tape is asking for trouble.
FordGirl!
05-25-2023 11:02 AM
trick26
11-15-2022 07:26 PM
Doc
11-27-2018 09:47 PM
76f350spercamprspeal
All Other Items for Sale
05-29-2014 05:31 AM
Quick Reply: Need Fender Trim Piece
