75 f350 dually
75 f350 dually
Hi everyone I just bought a 75 f350 dually with a dump box on it for use on our property. It has the 16.5 inches wheels on it and I am wanting to replace them with a 16 inch rim so tires are much easier to find. Is there any used one that would fit? What size does everyone recommend I would like to stay as close to factory as possible. Thanks for the info.
You will need coined wheels, just as your current ones are.
The lug nut holes are beveled. The holes alternate between being beveled in and out. This allows dually wheels to kind of lock together when they’re installed, and also allow them to center on the axle.
They’re hard to find wheels. Dodge used them up until ‘92 I think. Ford used them from ‘78ish until ‘84 I believe.
racetrips
05-16-2005 12:48 PM
