First generation Ford 1 ton truck
I was at Shelburne Meusum in Shelburne, VT and they had on display a 1924 Ford TT 1 ton truck on display, the first generation Ford Super Duty.
First generation 1 ton truck
Info about the Ford Model TT truck
Check out those contoured massaging seats
Just an ammeter dash instrument!
The following 5 users liked this post by SailorGuy:
The following users liked this post:
"The "F-Super Duty" (as the fender emblems stated) models appeared from 1987 to 1997. They were basically F-450s built as an "incomplete vehicle" (chassis cab) due to the fact that there was no bed installed and an aftermarket bed (specific to its future use) was added after the truck's initial build date. It came with dual fuel tanks with a dash-mounted toggle switch to switch between each tank while using only the one fuel gauge. It came with a PTO (Power Take-Off) used to power attachments (like winches or a dump bed) from the transmission. They were rated at about 15,000 lb (6,800 kg) GVWR (Gross Vehicle Weight Rating). They came with either the standard 7.5 L (460 CID) gas V8 or the optional 7.3 L (445 CID) diesel V8. All wheels were 10-lug with DRW (Dual Rear Wheels). This model should not be confused with the "Super Duty" commercial line of trucks starting with the 1999 model year."
The Super Duty name was first used in 1958 for a line of commercial truck engines.
https://en.m.wikipedia.org/wiki/Ford_Super_Duty_engine
Didn't Pontiac also have some big blocks called Super Duty?
Didn't Pontiac also have some big blocks called Super Duty way back when?
The funny thing was that that factory SD Pontiacs used that same Ford truck hood scoop.
Curated Content Editor
General Automotive Discussion
09-20-2022 02:12 PM
04-11-2017 05:45 PM
11-23-2016 11:23 AM
