PCV Valve hose?
#31
#32
@Franklin2 @FuzzFace2 the line coming off the T goes to the distributor cap. The large line in the front I mispoke, it goes to the grey box thing in the front passenger side. Pics below.
This line attaches to front of carb.
#33
#34
#37
That is exactly where it goes. It should be part of a plug that is laying on the driver's side inner fender. The temp sensor wire will go to the same place. You can see in the diagram the oil pressure wire is white/red, the temp sending unit wire is red/white.
#38
#39
#40
#41
Sooooo turns out the random hose I we all though came from the oil pressure switch actually is off the distributor and is correctly placed. I checked and my oil pressure switch is fine. I replaced the weird t-post looking connection with the original "tree", vacuum covered the unused ports and everything seems to be running smoothly.
#42
Donna1$
1997-2006 Expedition & Navigator
08-02-2022 03:12 PM
