1953 Ford F250 Deluxe Original
The following users liked this post:
I found the truck in Montana. To answer your question it has a v-8 flat head. I did not realize it was a deluxe until I got it home. I started disassembly and found that every single component, wiring, mechanical, etc. was shot. Every body panel needed huge amounts of work.
I printed off a copy of the workshop manual and the parts book [with the exploded views of all mechanical stuff] and went to work.
Tear down went pretty well. As I proceeded I realized that the truck was involved in a head on collision at one point. The front spring brackets were torn off and they welded new ones to the frame. Also the springs were not original. The radiator was replaced with one that actually worked pretty well. The front brakes had all the guts taken out and the brake lines were simply squeezed shut.
A few more pictures during tear down. The Ford parts book was very helpful just to see what parts I was missing. Most of the photos I took really helped putting the truck back together. When in doubt take more pictures. Also a large supply of zip lock bags were used and properly labeled. I also made sure I kept every old part off the truck no matter how worn out. While this was my first project of this size I was simply following the sound advice of the members on this forum.
The following 2 users liked this post by 1952henry:
The brakes were quite a bit more difficult than I thought. The front brakes were gone and to make matters worse all the bits that you need to put it back together were gone too. There is a small spring in the brake components I needed that was simply unavailable. After long searches I finally found a supplier that had one. It was like a miracle. Most of my parts came from either LMC Trucks or Mid-Fifty. I suppose I could have updated the brakes with disc brakes. Of course all the lines and everything else associated with the brakes were in desperate need of replacement. At this early stage I realized how foolish my budget for this restoration was. But for me it was journey getting to the final product and the knowledge you would learn on the way.
The following 2 users liked this post by WRCR:
might be just me or tha angle of the pic or a low tire, but that frame looks like it's got a twist in in
front frame rails aren't same height
did you check plumb and square on the frame..
also set the frame shimmed up on jack stands (in the middle of the frame not the ends) with the frame rails level both ways and check
the height of each corner from the floor (if the floor is level)
I know you're a ways past this point but if it ain't plumb and square it
will cause you problems at assembly time...and driving problems..
also check diagonals to check for a rack in the frame (one frame rail further forward than the other)
john
john
The following 2 users liked this post by jniolon:
