TFL - 2023 Super Duty
The following users liked this post:
BTRV did one on the F-450 and shows the interior with some detail where TFL pretty much skipped right over it. I really like the King Ranch, the dash looks great. Ford moved drive mode to the 2h/4h from the gear shift from what I saw. Isn't it in the end of the shifter for the 10 speed now?
I saw this:
Here: Ford Super Duty Reveal
I haven't seen anything else about the axle. The article mentioned a few new things I hadn't heard yet, like the 6.8 supposedly replaced the 6.2 because of added Low end torque to make starting up hills and merging onto the highway easier. It also mentioned seven new grills because Ford wanted to make each trim distinctive.
New for 2023 is the XL Off-Road Package for the F-250 and F-350 that provides 33-inch knobby tires, axle vent tubes, skid plates, a raised air dam, and an digital locking rear differential. Lastly, the Tremor Off-Road Package has bespoke suspension tuning (with a lifted entrance finish), a Dana entrance axle with an LSD and vent tubes, 18-inch wheels wrapped in 35-inch Goodyear tires, and selectable driving modes.
Nicely done ford.
I just saw another one he posted and the XL guys should be pretty pumped. XL now comes with 8 inch screen across the board, 6.8 gas standard, and STX comes with fogs and LED headlights. Nice upgrades. I chose a lariat for my 22, but had an XL f150 stx that I just traded and I would absolutely look at a STX and throw a leather kit in it.
Nicely done ford.
Nicely done ford.
that ford guy gave me the impression he was just some kind of spokesman. when pressed about the axle he seemed to stumble a bit. but he did say the front is a torsen and has been even on the 22 models according to him. i freeze framed a video and the rear looks to still be the m275 if you zoom in
that being said, I don’t recall if the 22 tremor uses a Torsen LSD, the raptor started using Torsen a year or two ago, but I don’t recall if anyone confirmed it is used in the super duty.
You are right, the guy referred to the front as “front locking differential” when it is a mechanical limited slip, someone familiar with 4x4 trucks would usually make a distinction between the two, even if the LSD is gear driven, you can’t switch it on and lock the diff.
