DEF warning question
2017 6.7
so over the weekend i filled my DEF (it was half before i filled up, not empty). yesterday on the way home an alert chime came up and said def
speed limit to 55 in 40 miles. i have 30 miles to get home so i got home and turned truck off and later went out to go somewhere and no warning light.
this am the alert came up again (DEF fault speed limited to 55 in 46 miles.).
what is this caused by and what to look for to correct?
The following 3 users liked this post by rtraviator:
The following users liked this post:
it’s in the services section.
if you have forscan on your phone you can run it from there. You don’t need the laptop version.
ok
i tried to use my phone but the adapter wasnt able to connect to my phone-
the alarm didnt come on today which is odd.......
i topped of at the station at the pump so i dont think it was contaminated......
i will hook up a scanner and see if it stored a code........ besides the one (P220E)for the nox sensor i havent figured out yet
Mine got confused like that after a heavy tow when I ran it till like 500 or 250 warning. Was getting 5-8mpg for a few hours.
Put a jug in and the 250 warning light came back on shortly after. Which wasn’t convenient since I was about 200 from home.
Long story short is run it for a while and it will probably adjust back. It was a little off for a moment but above 500 range so no light.
Yeah, probably a NOx sensor. I think they are a backordered part these days
