Tie down hooks for bed
Does anyone have any recommendations for tie down hooks for a 2022 F250? Mine has two in the front but would like to put two on each side of the bed. From what I've seen, and maybe I've just not looked enough, most tie downs are two pieces, where you buy a part that attached permanently to your bed then the hook is separate. Are there any one piece hooks that anyone is using and are happy with? I don't need them to hold a ton of weight but they come in handy to tie down various things while camping.
Ive used a aircraft style system like this in my last two trucks. two eight foot strips on each side of the bed Long bed ) and 3 6inch placed on the bed rails, with D rings and cargo ratchet straps to secure anything.. I would be cautious about ratcheting too much with the aluminum bed . Shop around to find best pricing but you get the basis of design
https://www.uscargocontrol.com/produ...track-aluminum
https://www.macscustomtiedowns.com/c...nt=Tie%20Downs
The following users liked this post:
Mainly price. I don't need to spend a couple hundred for 4 tie downs in my truck. It seems the boxlink or boxlink style is all that I've found that will bolt up to the factory holes in the bed. Found a few boxlink alternatives on Amazon I'm likely to pounce on at this point unless someone points me in another direction.
I will second the e-track for the boxlink system. US Cargo Control has a ton of different accessories that makes it extremely useful for me. I also bought the e-track tracks themselves to install in my trailers so that I can use the same system in the trailers that I use in my truck. All in all, been very happy with the boxlink system using e-track.
The Boxlink hooks that go in them are still sealed in plastic under the rear seat. E track accessories work easier to me. Unfortunately I don't know if non Boxlink equipped trucks have the tapped holes from the factory or not. My truck is an XLT Premium, here's a partial shot of the window sticker that shows it as standard equipment.
Not a dumb question at all. It's actually the Boxlink system that came on the truck from the factory. Had to remove them and put them back on when I installed the DuraLiner but it's all simple bolt in.
I do see some cheaper aftermarket versions of the plates too.
