I have been thinking that a mod should merge 20,21,22 and 23
into a 20~30 BS thread. That would make it easy. The only question would
be. Do the subscriptions follow the individual posts of would that break then?
You could probably edit the old one and change the title yourself if you started it, just use the Go Advance mode on the first post, should work unless there is a timer on when a title can be changed..
