Who is running 37s or close to a 37 on stock wheels?
Looking for info on a 37” tire or something close to it on a 17-19 with level kit or a 20-22 with 3 1/2” spacer it 2 1/2” coil lift. 35s will be too small since stock on my platinum are 34.1”. I did a 2 1/2” ready lift coil lift which raised my 2021 3 1/2” over stock.
This is what it will look like. You'll have rubbing on the sway bar and radius arms.
https://www.youtube.com/watch?v=Zaex...&index=36&t=7s
that video helps a lot. I think I’m higher because I the ready lift spring kit says it’s 2 1-2” but it actually lifts the truck 3 1/2” on 2020 and newer they are incorrect in the advertising. Also I wonder if the 11.5” wide tire will help being 1/2” narrower on the inside?
I saw a guy (youtube) who put 37x12.5's on stock wheels with a 2.5" spacer lift, he claimed to have only slight rub sometimes at full lock. They were an all terrain type tire. It's possible his tire choice ran a little smaller than some others in that size.
wouldnt tire height have zero affect on tire wear? It’s the width that would cause that. I have 35 12.50’s on the stock rim with no abnormal tire wear so stepping up to a 37 12.50 should be the same I would think
