Rear differential questions.
Does anybody know if I can switch out these 2 differentials? The struts line up and leaf spring mounts. Only thing I ran into is the 2001 parking brake cable plate fits inside the rotor and not on the new rotor. I heard you can put the parking brake on the drive shaft. Am I wasting my time with this? Thanks
Left is off a 2006 v10 E450 ford bus. Right is off 2001 v8 e350 v8 cube truck.
Off the v10 e450
E450 is a longer axle.
2001 e350 damaged differential housing.
E450 differential
Off the v10 e450
E450 differential
pdombrowicki
04-01-2011 10:40 AM
