What did you do to your OBS today?
#211
Took her to the dump. Got home backed her into her spot and something was shaking to beat hell.
Opened the hood and the fan was wobbling like crazy. Shut her down and this.....
One was still mostly still in, the 3 you are looking at were not even threaded. I pulled them straight out.
Pulled it all apart to check for damage, fortunately everything, including the bolts were just fine.
The following 2 users liked this post by sswari:
#212
Found the reason for the loud screech/grind
For the past few drives I heard a loud rhythmic screech or grind on the passenger side.
Originally thought it was coming from the front, and after many attempts to find the reason (even replaced the bearings) I almost gave up. But then asked my wife to stand outside and listen as I drove passed.
She said it was the rear passenger wheel.
Sure enough.
After removing the drum I found the adjusting cable in pieces.
A deep groove in the rear pad right in the middle. Lots of dust. Cleaned things up and put everything back without the cable for now. Will go order 2 just in case the other side is gone or about to go.
Sure enough.
#215
Wiper motor and hood to cowl seal.
I took my wiper motor off last week. I put a new one on today, along with a new hood to cowl seal. I was struggling to get the wiper linkage back on the wiper drive shaft. I found a YouTube video that recommended boiling the rubber bushings. I heated them in a coffee mug full of water and it worked. I didn't realize I had intermittent wipers until last week, this being a project truck. Nice to have everything working. I also put seam sealer around the bolts in the cowl area that hold my firewall reinforcement plate.
#216
The following users liked this post:
#217
New injectors and fuel filter today
Replaced all 8 injectors today. The picture was of the old ones.
This was somewhat difficult due to not removing the throttle body. I imagine it would be easier with it out of the way...
I will buy a injector tester to see which ones are good and will keep them as spares.
and... as expected, another dried out vacuum line snapped, so I patched it like others.
#218
#219
#222
I have the 1991 ribbed sealing surface on my E4OD transmission pan and Mark K. mentioned these type of pans need a cork gasket. I found a Mahle cork gasket and installed it after using a composite gasket that dripped some. The Mahle finally sealed the deal and no leaking or drips. Thanks Mark.
#223
Radius arm bushings, sway bar links, and coil springs
Hello.
Today I decided to tackle the radius arm bushings, coil springs and sway bar links on my F250 2wd.
Thought about removing the huge radius arm bolt, but that didn't happen and wasn't necessary. With sway bar out of the way, the axle beam and radius arm move just fine...
The passenger side took 3 hours with a couple of smoke breaks in between... Just had lunch and decided to post. Now will go do the other side.
1-1/8" wrench did all the work here
Rear half of the radius arm bushing out.
Sway bar link out.1
Same 1-1/8" wrench undid the nut
Realized that the sway bar had to be disconnected from the frame to give clearance.
Thought about removing the raius arm bolt but it didn't budge.
Pushed both the jack supporting the knuckle and the knuckle toward the front with my foot and then swung the arm to the side when it cleared the bracket. Front half of the bushing is out.
New coil spring installed. Moog severe duty (recommended for my truck). But it has one more coil than the spring i took out. It is supposed to be a variable rate spring, but i am a little worried about coil lock due to that one extra coil.
New radius arm bushing is in. Moog, rubber.
New sway bar link is in. Motorcraft.
Sway bar link out.1
#225
