Temp and fuel gauge
Old 07-27-2021 | 11:09 PM
Pappys53's Avatar
Pappys53
Temp and fuel gauge
All wiring done inside the cab. But my temp gauge and fuel gauge are not working.the ggauges are stock 53 f100. I am connecting a Chevy sender switch to the gauge. Could this be the problem? Which post should the power wire be connected to? Same for the fuel gauge, how do you know which post to connect power wire and which post to connect the wire from the sender?
Old 07-28-2021 | 12:31 AM
52 Merc's Avatar
52 Merc
Stock, 6V gauges must be used with the matching stock, 6V sending units. The Chevy senders won't work. Ford and Chevy gauges, especially the type Ford used back then work on a different electrical principle and are not compatible with each other. If you're running 12 volts, you'll need to add a voltage reducer to keep from burning them out.
Old 07-28-2021 | 11:05 AM
Pappys53's Avatar
Pappys53
I have voltage reducer. Does it matter what post the wires are connected to?
Old 07-28-2021 | 11:46 AM
52 Merc's Avatar
52 Merc
My guess is that it does, but I don't know what the wiring set up should be on a 53. The earlier trucks all have power going into the same place. Perhaps someone else can shed some light on that question.
Old 07-28-2021 | 12:01 PM
EffieTrucker's Avatar
EffieTrucker
Phantom of the Phorum
The original gauges are not polar sensitive. They work wired either way.
As Wayne pointed out, they will not react properly to a modern resistance based sending unit. As I understand it, the original sends a "pulse" type signal.
If you want to use the bowtie sending unit, you will need a replacement gauge.
1953-55 Ford F-100 Temperature Gauge And Sender Kit, With 1/8 Npt Sender, Mf (midfifty.com)
Old 07-28-2021 | 12:02 PM
bjmayberry2's Avatar
bjmayberry2
Got a picture of your 12v to 6v reducer? That may help identifying what end is what.
Here's a schematic of your dash gauges.
Old 07-28-2021 | 12:17 PM
bmoran4's Avatar
bmoran4
The stock sending unit uses the The King-Seeley (Ford Stock) principle. These sending units supply a full 6V through the heater wire in the gauge in the form of a square wave with the duration of the "on" being the variable determining the gauge reading. The longer the duration, the more fuel in the tank. It is this full 6v of current which heats the bi-metallic strip in the stock gauge that causes the gauge to read via a small gear train (that may adjustable). Most other makes and after market sending units are simply a variable resistor which sends a constant voltage to the gauge, lessening that voltage as the fuel level goes down. Therefore, the sending units signal doesn't heat the bimetallic strip in the gauge as much. Unfortunately, the calibration of the after-market sending units and the stock gauges don't match up very well due to the differences in the principle of the signal. Additionally, voltage reducers do not magically make incompatible senders and gauges talk to each other correctly either.
Bottom line, if you want stock gauges, you need stock style sending units. If you are running 12V, you also need to incorporate a voltage reducer.
Old 07-28-2021 | 04:51 PM
Pappys53's Avatar
Pappys53
I am using voltage reducer mounted on the back of the cluster housing. I attached the ground wire from the reducer to the housing. Do I need to run a ground wire off the housing to ground?
Old 07-28-2021 | 05:12 PM
bmoran4's Avatar
bmoran4
There is no point in running any wires until you match sending units and gauges.
Old 07-28-2021 | 05:28 PM
Pappys53's Avatar
Pappys53
Fuel sender in tank is ford. My gauge was working before I resisted my truck I hooked it up the same way. Wire from gauge to the sender and ground wire attached to a hold down screw to the frame.
Old 07-28-2021 | 05:38 PM
bmoran4's Avatar
bmoran4
On the gauge, one terminal goes to the sending unit. The other terminal goes to power ( not ground). In the diagram above, it is taken from the ignition switch switched power. The voltage reducer is likely to be installed between the ignition switch and the bus for the gauges, but confer with the voltage regulator documentation.
Old 07-28-2021 | 06:43 PM
shadderszxr's Avatar
shadderszxr
I’ve installed a universal wiring loom into my 51 F1 and this makes so much more sense now. Thank you for the clear explanation. Im going to check my gauges now with a low voltage varied input and check they react. Awesome 😎
Old 07-28-2021 | 06:49 PM
Pappys53's Avatar
Pappys53
Fuel gauge started working out of the blue. Here is a picture of top of my tank. Should the ground be attached opposite of the gauge wire or does it matter?
Old 07-28-2021 | 06:51 PM
bmoran4's Avatar
bmoran4
@shadderszxr , the proper way to test your stock gauges is in the service manual (pg 275 I think) with D Cell Batteries. A single D Cell should read half way, 2 D Cells should max the gauge out.
The following users liked this post:
Old 07-28-2021 | 06:55 PM
bmoran4's Avatar
bmoran4
@Pappys53 , looks like you could use some cleaning to make some good electrical contact, both on the ground and the signal wire. CRC 2-26 or similar contact cleaner as well as some scotchbrite to ensure good grounding through the bolt contact area and the spade terminal for the signal wire.
It seems you have wires in the correct locations, with the ground going to the screw on the outside and the signal wire going to the center terminal.
