Identifying rear axle
Hello I am trying to identify my rear axle in my 1978 f150.
I am not sure if the axle is original, it has no tag, has a sticker that is blank. It has the ford oval casted into it and "E5TW-AA" casted on the front. Has "5344" and a "3" casted on the back side. Has a 12 bolt cover, 8 lug hubs.
need to find out the ratio so I can match it with the dana 44 front.
Looks like a Sterling 10.25 from a 1985 or so F250. 8 lugs on 6.5" is the bolt pattern for those--is that what you have?
You should have 5 on 5.5" bolt pattern wheels up front.
Jack up the wheels and count driveshaft revolutions per wheel revolution. There were several ratios.
Can't get close? Pull the cover and count teeth.
turbogus
06-06-2011 09:08 AM
Slow
08-21-2007 03:20 PM
