Ring gear rust
Ring gear rust
Took apart my ford 9 and solvent washed it. The ring gear seems to have a small amount of rust that has taken away minuscule chunks of the gear teeth. When I run my finger over it I can tell that the metal is bumpy and no longer smooth. Pinion gear has no rust. Can someone tell me if this is will have an effect on anything? If so, is it bad enough that I will need to buy new. I plan to use the truck as a daily driver, but would really prefer not to buy a new set of gears.
The following users liked this post:
The spots around the pits are high points now.
If the gear set was in I'd say run it you'll probably get quite a ways on it. but since it's out and you have to set it all up again anyway it would be pretty dumb.
I guess it depends on if it's a junker or something you want right is how I'd play it. gear sets aren't that expensive.
Looks like what you find in vehicles that have been through a flood. Other parts need to be carefully inspected as well. Who knows what the high water mark was.
cbrown9064
04-01-2020 10:48 PM
loudoun
07-16-2014 12:22 AM
