F450 Lift Kit Questions (2019 Platimum)
#34
Decision has been made! Money has been spent - with more money to be spent ! First a big thank you and call out to three guys here who have been so patient and helpful: Compression-Ignition, island8, and speakerfritz.
I think I have pieces of all of the advice in what I am doing. Invoice is below, but it does not include the custom block because I need to send a pic of my rear springs as they wanted to know if I had upper overload springs (??). So I am going to send a picture and then that will be an additional $400, supposedly no up-charge from PMF who makes it, but that includes the U-bolts, the bump stops etc. So I think this is the only area I am out of the guidance as Island8 recommended not doing a big block in the back (6"). This will keep a 1.5-2.0" rake which should level out with my camper on it and perhaps I can avoid air bags. I also like the aggressive look of a slight rake as well. So, for $400 I can make a future decision on the rear suspension. I did not increase the wheels to 24" and am just sticking with the 22" (not sure I can even change my order at this point) and am planning to go with 37". The last item is the steering stabilizer, and I do plan to get that, it doesn't look like PMF or CJC offer one on their website for the F-450 so am going to ask CJC when I email the pic of the springs. They said it was a 4-6 week lead time, which I was suprised it wasn't longer, but where they are really behind is in their custom radius arms. So since I am not doing that now I am good. When I get this done I will post it all and hopefully help my fellow F-450 friends navigate this ocean of options. Thanks again.
also, once you do this kit, your steering wheel will be about 1/3 of a turn off.......I currently have this issue...looking into either a steering arm drop or a track bar extension. youtube says just turn the locking collar until the steering wheel is back center...but...not sure how much threads are avail.
at 4.5 you should check with PMF about transfer case drop bracket...especially if you will be off roading with extreme extensions.
let me know what you do about the steering correction....steering arm drop, track bar extension, or just adjust the collar. im still deciding.
also, rear replacement blocks should be tapered. PMF sells tapered and non tapered as an example.
you may need summo springs instead of bumpstops
when done measure your front sway bar from inside edge after the turn to the nearest bolt. mine are about 3" on both sides now....BUT..I had to go back in and loosen the sway bar bracket bolts and bang the bar with a 3lb rubber mallet until both sides were the same.....then tighten them down. if you have a 1/2 inch difference on your measure ments...your tire will rub on the side that is greater. simple thing to check and fix.
agree on the 22.5's instead of the 24's. look for a high rim rating for the rims. look for high ply tires (16 ply) and mixed use threads or off road threads.
on the rims, if they are polished on both sides, you can rotate front to back. the inners can be rotated using the spare.
use a PVC gasket inbetween the rims and hubs on the front, and a PVC gasket between rear inners and hub and rear steel and rear aluminum....6 PVC gaskets in total..this will prevent corrosion rings on your rims...makes it easire to rotate.
spray the inside steels on both side with a thin coat of fluid film, then spray both insides of the rear and front rims with fluid film....this will prevent pitting due to mositure and brake dust.
keep up posted.
im probally going to go with this pitman arm if I can confirm it will fit. I dont want to use the turn the turn collar method and reduce the number of engaged threads.
just posting this misc info...in case its helpful.
#35
Thanks so much. I still need to send in my pic of my rear springs so I am going to summarize your recommendations into bullets and ask Paul to respond to these questions. I am getting this done at a local shop (have 2 I have requested quotes from) so want them to have everything they need when I take it in given the supply chain issues. Also need to nail down my steering stabilizer yet. I will keep you posted!
#36
The following users liked this post:
#37
#38
I'm about to order my 2022 F450 and came across this thread and your picture. Just wanted to complement you on this stance and appearance. Later in this thread you mentioned towing heavy, but those 265s look like their on the stock 19.5" wheels -- aren't the factory wheels too narrow to run the 265s safely at capacity?
aside from the flying off the rim theories , larger size tires than the rim is rated for will at least increase tire center area wear due to bowing .
different tire manufactures have different tire/wheel combo recommendations and it may not be impossible to find a 265 tire rated for stock width rims.
#39
#40
you also have to look at the weight rating of the new wider rim.
i went down this path and either could not find what I wanted or got zero response from manufacturers that could produce a wider 19.5 10 bolt rim .
i wound up with buytruckwheels bolt on 22.5 10 bolt rims which at 6.75 wide supported toyo 37s. Rated at 6000lb each.255/70r22.5
the cost for the tire and wheel package was less than the potential cost of the perfect solution rim.
#41
do you love it. I am having a guy do it down near riverside.
#42
I'm looking at the Styker 4.5" 4 link lift kit. This seems a very expensive way to go though. Almost $6k when you add shocks and steering stabilizer. I am going to run 24" wheels (on order already) and 37" tires.
I did a forum search and did not see any reviews/feedback on Stryker. There are less options out there for F-450 lift kits than the other Super Duty's. Seems that some just put a leveling kit on the front and call it a day, but I would like a little more height. I have a truck camper though and tow a 1,000lb tongue weight BBQ trailer as well, so if I put a level kit on it I will squat when loaded. Right now it squats to level when I load it with camper and trailer. So if I did the leveling kit I assume I'd need air bags in the bag when loaded to level it out.I also would not want to go any higher than 4".
Am I missing something? Is there a better way? I also want a decent (not great) ride. I'm hoping a 4 link would improve the ride some. I am not going the Keldermen route. Expensive and air systems need maintenance from time to time especially in the salt and ice road conditions of the north.
Hoping for some advice and recommendations from the experts! Thank you!
what is the tire and wheel specs on this setup? Looks like factory wheels with rear spacers? Im assuming probably had poor tire wear if thats the factory wheel. Thank you
#44
that new setup looks amazing! I really would love to make it work with your original setup . What was the tire size? and did you have any bad experience with running it ? Were spacers a must too?
thank you for your help !!
#45
More than happy to share everything I did on this truck. I love how it turned out and am very happy with the drive quality. Tires: 22 x 38 x 12.5 and no spacers, direct bolt on. Wheels are from JK Motorsports and they cut them there. There are the diamond pattern in black. Spike lug covers.
