What’s your current set-up/tire pressure
The door jamb sticker gives you the minimum pressure(s) while the maximum pressure is listed on your tires. Having owned several Ford products, I have found their minimum pressures almost always cause premature tire wear. I run 72 PSI F & R for better tire wear, fuel mileage and handling. If you're running lower pressures for the sake of ride comfort, you're in the wrong vehicle.
The following users liked this post:
65 in the front, 55 in the rear.
I'm running the NItto Tera Grappler G2's in 35x12.5. I looked at the inflation guide and can run my rears as low as 45 for the load I carry with my toy hauler. I have been experimenting with 55, 50, 45 and making sure empty the tires are wearing flat. I'm doing the old shoe polish trick or using the light dust that gathers on the flat driveway at my vacation home to see how the tires are rolling on the ground.
I run my tires low for proper wear since I spend a lot of time unloaded. The door jamb is a guideline, go to the tire manufacturer and you'll get a better idea of how much pressure the tires should have for a given load. Running in the 60+ psi range unloaded, I just wear down the centers of the tires, it's too much pressure for an unloaded truck.
Weigh my axles
Multiply the maximum tire load by 2
Divide the actual axle weight by that ^^^ doubled maximum tire load
Multiply the quotient ^^^ by the maximum tire pressure
Example
5000 front
3000 rear
80 psi tires rated at 3750lbs
3750 x 2 = 7500
5000/7500 = .67
.67 x 80psi = 53.6psi front
3000/7500 = .4
.4 x 80psi = 32psi rear
I'd probably go 55psi front and 35 psi rear unloaded like that. Hauling a decently heavy trailer I usually just air the rears all the way up and leave the fronts. I might put a little more air in the fronts for a long tow or something actually heavy.
I've never had issues of the tread not wearing flat using ^^^ this method. And bonus when I check the chart it always shows that I have over inflated by some degree, so I figure it as an extra safety margin.
YMMV
What is everyone’s set up? Are you stock? Lifted? Leveled? And what psi do you run? I have a 2” level and don’t really tow much. My tires are 35x12.5r20 and I have a 4 door 6.7 limited.....front tires are at 65 and rear at 60 psi. I believe the max psi rating on these nitto ridge grapplers is 80 psi. Not sure what I am supposed to be running since I don’t tow much.
Your truck should have a sticker in the door jamb and it gives the max payload and the psi. NOTE!!! the psi given is the psi for the payload weight. Note on my payload/psi sticker what mine is and what I actually run unloaded is 70 psi all the way around.
Every tire mfg has a chart like the one shown for their tire and its psi based upon the payload.
After all this which you need to take note of is the CONTACT PATCH. That overrules every thing because its where the rubber meets the road. Take note the outer edges of my tires were not touching pavement unloaded so I reduced the psi to 70 psi.
Hope this help you out...
This my payload/psi sticker and my psi/weight chart for my tires.
Another stupid question; should I be concerned if my tire pressure rises above 80 PSI when towing on hot days? Air down a bit maybe?
I'm running 77 in rear now, (DRW) and 70 in the front for a long trip.
Tire PSI is assumed to be set when the tire is cold. Tire manufacturers take into account that pressure will increase with a rise in temperature and load. So no ... it's of no consequence for them to exceed 80 PSI (if that's the maximum listed on your sidewalls) when towing on hot days.
Truck is completely stock running the 275/65 18RE Continentals that came on it. At first I thought the truck rode a little harsh, so I came down 5 pounds off the sticker all the way around and that seemed to help. Then gas went through the roof, so trying to get every drop of MPG I can out of this beast I pumped the tires up 65 front, 75 rear.
I then found it still seemed to ride pretty well, for a Super Duty truck with a 3400# payload. I guess the tire sidewalls just needed to break in a little. 4500 miles now over 7 months of ownership.
#29
I scale the truck and do the math based on the the tires capacity. This is used to determine the minimums.
