460 score
#481
Again, I'm not following you. Or you're not following me. As I said, the first two journals I checked were number's 1 & 5. That's the two ends. There was no runout between them. And with the dial indicator still zero'd on those two journals, I checked the center three journals. No runout. Can the camshaft be straighter than that?
#483
I've got a new AVS2 1912, 800 cfm carburetor that'll go on the 502.
10/4 thats what i went with,,,,,,and on my startup it ran well, I questioned weather i should go with the 800,it wasnt out yet and summit told me to hold off until its released .Glad you said your going with that. for conformation
#484
#485
It just doesn't work like that. First off, it can't be checked in a lathe, you need V blocks. Checking the center gives you nothing more than an overall reading and that's not what you need to be looking for. ( Straightness is checked from supported #1 & #3 journals out to an unsupported #5 journal and viceversa ) your checking the relationship between each half of the shaft. Like I said, a cam can be out on one end and you may not even notice it just checking it in the center. I don't know how else to explain it. Set one up and try it, you'll see what I'm trying to say.
#486
#487
#489
Ok, I've got V-blocks and tried it, using the original camshaft I bought when this was still a 460 build. Btw, I also mocked up this camshaft in the engine when I first realized I had a problem a few weeks ago. It was exactly the same as the camshaft I'm using. Anyway, this morning I used my milling machine's table for V-block set up, since I don't have a granite machinist's block. The results were the same. I still thought I might be missing something, so I called two friends that each run machine shops. One is a CNC production shop, the other an engine machine shop. Both said same thing. The camshaft is produced between centers. If it truly indicates true on all five journals when set up between centers, then it cannot be anything but straight when set up on any combination of journals.
#490
That's good you got a straight one. The problem with their thinking is the cam does not spin on dead centers. The relationship from center to end is what matters. If you ever come across a motor that lost a cam bearing odds are it will be either #1 or #5 and this is why.
You are correct that the camshaft does not index on the center drilled holes while in the engine. But when the number 1 & 5 journals are concentric with the center drilled holes (confirmed), and the number 2, 3, & 4 journals are concentric with numbers 1 & 5 journals (confirmed), then the camshaft is straight. And btw, a precision lathe is a much more accurate measuring fixture than two independent V-blocks.
#491
Parts are rolling in this week. Ignition system, fuel pump, and a few other goodies should be here in the next couple of days. The CVF Racing accessory drive was delivered this evening. I immediately mocked it up for pulley alignment check and just to look at it. The following pics may not be suitable for younger audiences.
#493
No ac in this truck. But if I decide to later, I can change alternator bracket, and add ac bracket. Yep, a very nice FTE member, "Somethingclever", sold me that RPM Air Gap. Things are falling into place!
#494
The hurricane blew itself out before it got to us. We did have 65 mph winds and lots of rain, but remarkably no structure damage here. The tornado that came through the next day did more damage. And then like a dumbaxe, Saturday I got my legs pinned by a 25k lb chain when it tightened up between a dozer and a tractor. Didn't break any bones, but busted a vein and lots of bruising. What an idiot! Engine build negates all that horse crap though.
#495
The following users liked this post:
