2020 or 2021 Airbags
I've put airbags on all my previous Super Dutys and will put them on my '21 when it finally arrives.
I think it makes a great improvement of ride quality when towing a heavy 5er.
Firestone Airbags with remote controlled air compressor is the way to go. Unloaded I run 5 psi, loaded 65 - 75 psi.
My F350 squats 3” when I have my 14,000 5th wheel mounted. It handles fine and rides nice like that. I have 7” of bed clearance and the RV is level.
The only issue is headlights at night are too high. I don’t tow at night so it’s not normally an issue. If I were to be driving it at night I would get airbags. But the again airing up the airbags would cause the RV to ride nose high.
[QUOTE=ThumbsUp;19835859]I agree with others. I don't think you will need airbags. I have a 2019 F350 diesel shortbed and tow a 12K GVWR 5th wheel and also have a 260 lb B&W Companion Slider in the bed. The truck and trailer sits level and it tows great.
[/QUOTET)
Thanks for the replies fellas!
Ill hook it up and see how it looks. We are getting our new Grand design 311BHS Thursday! Can't Wait!
[/QUOTET)
20 or 21 airbags
My 2019 F-250 has manual air bags and adjustable Rancho 9000XL rear shocks. I tow a 12,000 5er on long trips a couple times a year. The Rancho 9000s set at max setting really helps control cringeworthy, terrible bridge approaches and uneven road.
I manually pump the Firestone air bags to 40-50 PSI. Rarely need to add air. No squat. Rides as well as a truck towing 12,000 can.
Magnolia Tom
Fifth Wheel & Gooseneck RV Towing
10-07-2014 09:01 AM
sumbuddyloanmea.10
08-22-2010 07:08 AM
