Wire connector help F53 Motorhome Chassis 1991
Old 03-11-2021 | 08:01 PM
sporcher's Avatar
sporcher
Unhappy Wire connector help F53 Motorhome Chassis 1991
I have a 1991 Fleetwood Bounder 34J which is on the F53 motorhome chassis with the Ford 460. I was moving it around my parking lot earlier and it started to die each time I put it in gear. Ran fine in neutral/park but move to drive or reverse and it died. Then it stopped altogether and would not start. After a day of spit balling and changing out the fuel pump still had the issue. Took a look underneath the driver's side and saw a couple of wires wrapped in the steering column/knuckle. Got them worked back out and the RV started up. Thought it was success. But then it died when putting in gear again. I have found some wires "pulled out" or shorting in a wire connector near the base of the steering column. I have no idea what the connector is - but I am hoping someone can help me. I am not an electrician or mechanic but have a friend that can help if we can find out what this connector is. I would be grateful for any help! Thank you. Sean
Old 03-12-2021 | 09:01 AM
subford's Avatar
subford
Can you back out some so we can see where the location of where the connector is.
Also can you show the wire colors of the connector.
Is the connector in the drawing below?
Old 03-12-2021 | 10:07 AM
jackietreehorn's Avatar
jackietreehorn
If its like the trucks, that harness likely contains the fuel pump relay and ECM relay power from ignition. A good place to look. I have personally seen a truck where the main relay power wire corroded internally. I recommend getting a wiring diagram packet from ebay or a Haynes manual at the very least and go to town with a VOM. Find out where the power is getting lost. Easier than you think.
Old 03-12-2021 | 10:19 AM
sporcher's Avatar
sporcher
I am going to print this out and take it over to the RV now. I will report back. Thank you so much. Really hoping to get this fixed over the weekend.
Old 03-12-2021 | 01:08 PM
sporcher's Avatar
sporcher
Subford-
Thank you again for the diagram. I tried to take some better pictures. There is a big wire loom about 1 1/2 inches thick that runs back from this area. That loom has four smaller branches and this is one of those branches. It looks like a prior owner has already made some adjustments here with some wires coming out of the loom. I believe this connector is in the diagram on the top. I am curious if this is a straight through connector so I could technically bypass it with jumper wires?
Thanks for your help it is greatly appreciated.
Old 03-12-2021 | 02:16 PM
subford's Avatar
subford
This should be the connector:
Old 03-12-2021 | 03:06 PM
sporcher's Avatar
sporcher
Thank you!!! So there was a repair done it apparatus to the red green wire. The connection inside was open off/on. I cut the wire on both sides of the connector and jumped across! Now it is working. I feel I should probably fix it right at some point. Thank you for this it was a big help!!!!!
Old 03-12-2021 | 03:34 PM
subford's Avatar
subford
I re-posted that connector above with the wire sources.
Old 03-12-2021 | 03:40 PM
sporcher's Avatar
sporcher
Talking
I am really thankful! I appreciate your help!!
Beefer Tracy
08-08-2020 12:10 AM
Bigfoot0220
06-15-2019 04:01 PM
88f1504x4
12-05-2011 09:25 PM
sprint
11-17-2007 04:12 PM
Robber80
1999 to 2016 Super Duty
04-22-2007 05:33 PM
Quick Reply: Wire connector help F53 Motorhome Chassis 1991
