2021 F450 leveling
2021 F450 leveling
Hi all,
What is the best way to choose between the many options of leveling my soon-to-arrive 2021 F450 King Ranch? I don't necessarily want to lift it... just level the front a bit for the overall appearance.
It sounds like there are options from a variety of suppliers. What do I need to know about their quality Do? Do I want a coil spring leveling lift or just use spacers? Sounds like the track bar setup will need to be modified as well.
I dont want to spend a fortune, but I also want to keep reliability and quality. I guess I'm looking for the Good/Better/Best approaches and the pros and cons of each. I've tried searching the forum but there's a lot of content to sort through and try to make sense of.
Thanks in advance
Jonathan
Thanks in advance
Jonathan
The following users liked this post:
Just picked mine up a few weeks ago, it sits pretty level. If towing with it a leveling kit may be a bit much. When i hook a trailer to it with a load it drops a few inches in the rear.
I think i may go with a kelderman air ride in the rear for a better ride and that could be used to give the appearance you are looking for. Just my 2 pennies.
The next truck will have stock suspension, at most maybe a leveling kit, which I'm still debating. Kelderman is great for a show truck but if you want to have it on a truck you'll own for more than a couple of years, good luck. We've been very disappointed. Looks like they're turning into more of an Instagram/Show Truck company rather than offering reliable, practical solutions. It's sad...
Well, I really like the ride of the Kelderman overall. And it makes me sad since they're the only company out there offering a proper air-type suspension for these trucks. But unless they've decided to get serious about the professionalism of their install, I'd stay away. It may be worth a phone call to really search all that out. You might do your homework and end up with a good experience. Mine sure wasn't a good one, but I'll miss having the auto-leveling suspension, for sure.
Here is a pic of my ‘20 450.. I like how it sits from the factory. I looked at a bunch of stock pics before I ordered, and I found that adding the heavy front suspension alone was my preference for how it makes the stance.. And I honestly can’t tell a difference in ride quality.
Thanks! If you didn’t order the heavy front suspension option on your truck, I would definitely consider adding the heavier factory springs that come in that package. They are pretty reasonable, and every 450 that I have seen with them sits nice from the factory.
