302 oil pan question
Old 11-21-2020 | 09:55 PM
Recoil315's Avatar
Recoil315
1972 4x4 truck with a 302 V8 (not original engine). I'm wanting to replace the oil pan because a prior owner must have had a leak around the dipstick and decided to put silicone all over the inlet flange.
I'm having trouble locating an exact match for this pan. I believe it to be a rear sump and the dipstick on the passenger side through the oil pan.
Oil pan stamp is DITE (unsure of the next numbers..but either...) 6675-BA or 6875-BA.
What replacement parts are out there?
FYI.... first post, still learning my way around. Sorry if the pics are too big.
hanks for any help available
Old 11-21-2020 | 10:26 PM
ford390gashog's Avatar
ford390gashog
That's a Econoline oil pan. You can use the bronco pan. https://www.wildhorses4x4.com/produc...ronco_Oil_Pans
Old 11-23-2020 | 03:34 PM
baddad457's Avatar
baddad457
Can also take it off, clean it up and have the dipstick brazed back in place.
Old 12-01-2020 | 09:42 AM
Recoil315's Avatar
Recoil315
After doing some more research, I have finally located the exact oil pan that I have. Strangely enough, I found it listed as a Mercury Marine, Mercruiser Sterndrive 888 boat application.
Has anyone ran into something like this?
More than likely, I will take the advice of baddad457 and just have it properly repaired.
Old 12-01-2020 | 11:05 AM
baddad457's Avatar
baddad457
Many Ford/Mercury parts had more than one application.
Old 12-01-2020 | 11:18 AM
ford390gashog
Yes it probably had other applications. The primary was the Econoline.
Old 06-13-2021 | 07:57 AM
diggerrigger's Avatar
diggerrigger
Reply deleted
tigerfan79
09-20-2020 11:19 PM
hello113
01-27-2019 01:39 PM
lm987
29
08-09-2010 09:55 PM
solid dakota
07-19-2004 05:22 PM
pinegreen
11-15-2000 09:17 AM
