ARE Caps.. Anyone?
#61
I’d want the weatherstripping stuck to the camper AND wide enough to completely cover it so it didn’t rub my trucks bed at all.
im sure the sticky foam would be a real pita getting all of it off your truck bed.
I’ll be removing the shell after I return from AlaskA & don’t want ANY signs it had a camper shell on it.
#62
#63
I have had an ARE shell on my Chevy Silverado (I know, I know...I am being reformed) for 9+ years and it has worked well. The hydraulic lifts need on the back window need to be replaced, but other than that it has worked great. No leaking at all. The paint matches perfectly and aesthetically, I felt that the ARE shells looked better than the others out there.
#64
Question for you guys with Caps... How much water leakage are you having when it rains? I mean I expect some water around the door, but I seem to be getting a lot. Might need to bring it back to the canopy dealer I got it from. This was after driving home in a hard rain.
#65
I have the bed rug as well. Not sure it leaks like that. All I noticed were a couple spots near the tailgate. That was solved by buying some 'D' foam weatherstripping on amazon (5/8") and adding to the current tailgate seal.
#66
I guess we will see with mine. I don't thing the place I got the topper put a sealant down. Ugh. I have the spray in bedliner underneath the bed rug as well. I sealed the seams before they sprayed and glad I left the front drain holes open just in case.
#67
probably depends where you live. I'm in Pa, and even the dealers around here are all over the place on their prices. I got mine for $2850 and that included upcharge for white platinum paint, remote unlock, roof rails, drop down sliding front window and of course carpet but I think that's included.
#68
Honestly I just got it on so it still feels pretty rigid. I Don't think it will be a problem. There is a little flex to it but not much. ARE has a lifetime warranty on it so if I have any issues they can fix it.
One thing I did notice, is that in a heavy rain you still get some water coming in near where the door meets the top of the tailgate on the side. Not a lot, but enough to make the very back of the bed wet.
#69
#72
Chief1232 I have Leer cap on my 2012 that was added in 2013 and not a drop of water comes in to the bed even in the worst of storms. Not even from the rear door area. The reason for a cap is to keep the rear completely dry and out of the weather. Take it back and have the correct the seal that was used.
#73
Chief1232 I have Leer cap on my 2012 that was added in 2013 and not a drop of water comes in to the bed even in the worst of storms. Not even from the rear door area. The reason for a cap is to keep the rear completely dry and out of the weather. Take it back and have the installer correct the seal that was used.
#75
The following 2 users liked this post by V10DoubleTow:
