ARE Caps.. Anyone?
I have the z series but think there are better manufactures out there for frame less glass tops.
I saw a z series stule top that had better body stlye fit as well as obvious framed reenfocement with roof caps that cover usable bolt areas that transfer weight to the frame.
are told me they did not offer reenforced z series.
spent 3k on my z series and if I had to do it all over again I would forgo all these Kmart grade tops and go with a space cap. The space cap I was looking at with all the bells and whistles was just short of 10k.
thete is a lot of flimsy, loose, air space, gummy rig plastic to make one mold fit all, and they don’t follow body lines very well . You don’t know how bad it is until you get a leer, are, snug top, century, etc.
I put the decked drawer system in mine that way I wouldn’t be laying in a puddle of water whenever it rains.
and let’s not even talk about the rear window edge trim....
The dealer did raise it. I told them I wanted to see some black bed rail which they told me they have never had anyone request this. It is still very close but I don't think they could raise it any more without having it look weird. I was going to look into releasing the clamps and push the cap out a little and retighten. Haven't looked at this option and don't even know if this is possible.
I just had a Z series installed a few weeks ago along with the bedrug. Had just the rails added too incase I want to add anything up there. It took about 3 months to come in. I added some running board lights to the inside that I had laying around. I'm extremely happy with it so far. The white platinum was an exact match, I was worried about that.
The following users liked this post:
Here's what I think he means. It is a flap attached to the glass that you aren't supposed to touch when you shut the back glass. Its super annoying. They designed it away, but anyone that has it probably hates it.
I had to wait until daylight, here are the pics of mine. The owner has the same exact truck so he did the R&D to figure out the seal. He was pissed when he found out the installer initially put the wrong seal on and scratched the paint and the bed rails. (Again they went above and beyond to make it right). Its about a 3/8" gap now. And the cap does not sit that high and look funny.
I'll try and find out.
They supply the rails when you add the option during ordering, I think they work with both Thule and Yakima but I could be wrong. You can ask when ordering, I think you can buy the cross bars also to go with it. Might work with other brand too, depending what mounts/feet they use. I figured to add it to the order so it would be under warranty. If you were to add them later it voids the warranty.
My A.R.E. dealer told me yesterday, when I was placing my order, that they add the tracks after the cap arrives at their shop. They feel that they have a much better way to install them that is more trouble-free than the factory installation. They still order the caps with the extra fiberglass reinforcement for the tracks, if I understood them correctly.
They've been doing it this way for the past 20 years, and say they are the second largest A.R.E. dealer in the U.S..
I dont trust dealers, that's why I call around the area. One dealer wanted $500+ for the remote rear lock which is waaay over what I payed. Not to mention the range in prices from dealer to dealer. I ended up with more for less than some quotes on a no option cap, I'm talking hundreds. Ridiculous
#28
I ordered a Z on 10/29, so not clear if I get the "new" design or not. So this flap that you mention above that you aren't supposed to touch, I'm still not clear on why it is so annoying. Does it get in the way somehow, or is it easy to accidentally knock it out of whack, or what?
#29
Smoking Joe,
#30
