3g alternator swap
Old 10-14-2020 | 08:01 PM
John89's Avatar
John89
Sounds like me when I thought I screwed up my clutch replacing body mounts and all that was wrong is the floor mat shifted and wouldn't let the pedal go down far enough. If all our fixes would be that easy.
Glad you got it figured out.
Old 10-16-2020 | 04:18 PM
1TonBasecamp's Avatar
1TonBasecamp
Yay! Success.
Pretty sure they had to make that bracket at least semi adjustable to different size units, because even back then there were two distinct sizes of the old 1G alternator. The large-case model was quite a bit larger than the small-case model.
I was able to install a 105amp large-case model on my 400 without having to do anything at all. Even with my 302, the large-case 70a model bolted right on. I did make the decision to elongate the already slotted hole though, rather than drive over to the local parts store for a shorter belt!
But hey, that's what snap decisions are made for!
Let us know how it charges things. You should see a nice steady 14-15 volts even when at idle and some of the accessories running.
Paul
Old 10-16-2020 | 08:41 PM
tndallas's Avatar
tndallas
Originally Posted by 1TonBasecamp
Yay! Success.
Paul
Thanks for celebrating with me.
14.7 volts at idle with nothing on.
14.5 volts at idle with everything I've got. Headlights heater cab radio even the glove box light.
Superblue400
31
08-21-2020 12:47 PM
mustang81
12-29-2014 08:31 AM
66F500
12-15-2014 08:51 PM
whisler
18
05-03-2012 07:04 AM
dickdollar
11-23-2003 10:07 PM
Quick Reply: 3g alternator swap
