73 f250 2wd 360 front suspension
Old 10-02-2020 | 02:16 PM
bigoldtruck's Avatar
bigoldtruck
Steering wanders, and the radius arm bushings look shot. So I am planning my attack.
I have a couple questions. First, how? It looks like I need to unbolt the bushing end of the arm
from the mount (where the big rubber donuts are). And then that arm needs to move forward
about 4 inches so I can get at the second bushing to replace it. I have read on here
about a method for this that involves a come-along and leaving the big bolt under the spring, bolted up.
I don't see how that can work as even if the i-beam moved forward it would run into the other I-beam in one inch.
So it looks like I need to take apart the stuff at the yoke end of the radius arm. Is that right?
And second, I jacked up the drivers side wheel and pried and wiggled at it, and the only
movement I can find is about 1/16" up and down at the kingpin. Is that a problem or can I leave it go?
I am in the parts-ordering stage now. So, third, are NAPA's rubber radius arm bushings okay or are the urethane ones
that much better? I won't run any sport car rallies, but I do want to stay in one lane on the freeway.
And fourth, any other things likely need replacing while I am in there? Steering rods and couplings
pass the wiggle test. Shocks are already on my list. I don't know how to test the coil springs, but if
I'm told they probably need to go, then I will get new ones. This is a very heavy, "hard duty" truck.
Thank you for any help.
Old 10-02-2020 | 03:46 PM
smle's Avatar
smle
Sounds like you also need to check the play on your steering box.
Old 10-03-2020 | 11:21 AM
bigoldtruck
I will do that. I started reading up on adjustment and replacement of steering box. Thank you smle
Old 10-03-2020 | 11:40 AM
F-250 restorer's Avatar
F-250 restorer
I have been through the steering issue with my truck, a '75. I found that I was not able to tighten the steering until I went through the entire system, kingpins, all tie rods, all bushings, and even the steering column. One tip: Don't waste money on a 'rebuilt' steering box. I R&R'ed two that were just as bad as the one I took out; except they didn't leak. I found out the hard way that 'rebuilt' means a spray clean and new seals. I finally paid the price and got a RedHead box, and that solved the issue for good. But even after replacing everything on the front end, I still had to rebuild the steering column. If the top or bottom bearing/bushing is shot in the column, then you get slop in the steering. Buy the best quality possible, and get a good strong light and check the frame around the steering box bolt holes. It is fairly common to have a cracked frame there. Good Luck.
Old 10-03-2020 | 11:48 AM
smle's Avatar
smle
If I ever have to change steering boxes, I'd spend the money and get either Blue Top or Red Top.
Old 10-03-2020 | 11:54 AM
smle's Avatar
smle
F-250 restorer is also correct in everything he said. Another thing adjusting the box does not usually work that well because everything is already wore out.
72CC428
05-29-2016 08:15 PM
Coastal68
03-27-2016 05:30 PM
John in Vegas
09-25-2013 10:27 AM
Saber123316
05-07-2010 06:24 PM
OneFine69
30
03-19-2007 04:22 AM
Quick Reply: 73 f250 2wd 360 front suspension
