AC Clutch wont engage
Old 12-19-2000 | 02:39 PM
Katt's Avatar
Katt
[font size="1" color="#FF0000"]LAST EDITED ON 19-Dec-00 AT 03:40 PM (EST)[/font][p]Greetings,
The AC Clutch on my 1988 F150 351W wont engage. It will if I jumper directly to the battery, but there is no power going to the plug on the regular harness. I have checked the in cab switch, and it is fine. Is this controlled by a relay? Any suggestions will be greatly appreciated.
Thanks
Old 12-19-2000 | 03:54 PM
Boykinfan's Avatar
Boykinfan
Your system could be low. There is a low pressure cut off switch on your accumalator.
Old 12-19-2000 | 05:44 PM
dave89f150's Avatar
dave89f150
Fords are bad about leaking freon. I converted my Mustang over to R134A, as it is cheaper to refill. The low pressure switch will not allow the compressor to engage to prevent damage(?). Does it cycle at all if on defrost setting?
Old 12-19-2000 | 07:37 PM
billyb's Avatar
billyb
try jumping the low pressure switch. it is connected to the dryer on the passenger side by the ac/ heat unit.
i agree that if you are leaking freon, it is a good time to convert. just do it right.
Old 12-21-2000 | 11:25 PM
Katt's Avatar
Katt
Thanks very much guys! I'm an idiot, I even remember installing that switch!
Old 12-22-2000 | 05:10 PM
deleontow's Avatar
deleontow
Him3000
08-06-2014 07:13 AM
crackerloco
08-08-2007 07:04 PM
mkistner
06-10-2003 08:07 AM
Brimhall
05-28-2003 11:18 PM
Holli
1978 - 1996 Big Bronco
15
09-11-2002 10:43 PM
Quick Reply: AC Clutch wont engage
