37 vs 35s - Ride Quality
Short Version: Looking for first hand experiences from people that have switched from 35s to 37s (or vise versa) on 17/18" wheels. Was there a big difference in ride quality?
The full story: I ordered a 2020 f350 Platinum CCLB 7.3L , should have it in a couple months. I'm in the process of research and parts ordering.
I use my truck as a daily driver in the western Canada oil patch. 300-500km a day on average, sometimes only 100, sometimes 1200. About 60-70,000km per year.
I travel a lot of "high speed" gravel roads, 50-65mph with lots of bumps, wash board, etc.
I'm mostly focused on ride quality. I've already decided on a Carli 3.5" Pintop system with all the options including rear deavers.
I'm also decided on 17" wheels, I like the look and they should give the best ride.
Here is what I cannot make up my mind about: Tire size
I would like to go 37's. I understand that they will fit with the proper offset.
I need to run mud flaps with the amount of gravel I drive. Going to use a set of "kickback" style flaps so I don't lose much clearance.
If I go 35's I will run Bushwacker pocket flares and a more aggressive offset wheel.
So from what I can tell here are my pros and cons:
37s
Pros
-Better ride
-Looks awesome
Cons
-Can't run a more aggressive offset and therefore I can't use bushwacker pocket flares (won't look right without the more offset wheels IMO)
-Might run into some rubbing issues when articulating offroad
-Heavy, will be harder on front end, brakes, etc
-some loss of acceleration (7.3L gas, 3.73 gears)
-I'm seeing fewer tires options that would be good for winter in northern Canada
35s
Pros
- Should not have any rubbing under any circumstance when off road
-Slightly more options for winter tires
-Cheaper
-Less weight and less wear and tear on front end, etc(This might be a wash since I will run a more aggressive offset with 35's.
-I'll have room to run a more aggressive offset and pocket flares
Cons
-Ride quality not as good.
-"skateboard" look
I've been debating this in my head for weeks now and it's getting to the point I need to make a decision and order stuff.
Looking forward to hearing your opinions!
37s
Pros
-Better ride
-Looks awesome
Cons
35s
Pros
-Cheaper
Cons
-"skateboard" look
This is why I run 35” on my 2017 with full 2.5 pintop. 18x9 methods with +18 offset.
I run mudflaps as well. Not sure about the 2020, but with heavy rear axle articulation I had to trim the rear corner of the fuel tank skid plate as well as the driveshaft would rub.
You won’t regret your choice as far as ride quality. Make sure you bomb down the Offroad stock...... the difference is amazing.
https://youtu.be/XvyGHcNwrbw
Sometimes these trucks look like skateboards with 35's and others (like yours) look great.
Looks like the cons list for the 37"is twice as long as the con list for the 35". I'd go with the 35", I doubt you'll notice any better ride with the larger tires and might actually have a decreased feel due to more sidewall give. I'll agree that a wheel well that's closer to full looks better but you have to leave plenty of room for the suspension to do its thing
I'm running the Carli leveling Pintop with the King's, radius arms and full Deaver leaf pack on Toyo M/T 37's and 17" Method's. 100% worth the 37's on 17's, more sidewall, which is far more forgiving on the small bump compliance. Been in the offroad racing scene for a while, the bigger the tire the better the feel and compliance to soak up what its going over. That paired with the Carli setup, you really can't go wrong and in my opinion for whatever it is worth, I think you will be very happy with 37's.
No, not at all actually. I had the kit installed at CJC offroad, I don’t think they had to do any trimming on the fender wells either if I recall correctly. Here is a couple of photos if this helps any with your decision.
The wheels are Method NV 17x8.5 and the back spacing is 4.75. If I remember correctly the offset is -12mm. Tires are Toyo M/T 37x13.50R17. I don’t have a photo of how far they stick out, but later today i can definitely take one when I get back home.
