The best Carb on the market...
The QJ is very versitile. With its three layer body, it was very easy for Rochester to pop different size orifices into the passage ways, different jets and m.rods, booster springs. That way they were able to install one size carb on any size engine. I personally run an 800 cfm QJ on a Ford 300 I6, and it works great! The tiny primaries flow 220 cfm, and the toilet flusher secondaries are controlled with a vacuum flap that gives the engine only as much fuel as it can use. It takes a lot of playing with it to dial one in, but once you find that sweet spot it's heaven--power and mpg. When I tow or haul, I pop the air cleaner off and turn the part throttle adjustment screw to make the afr mix richer, and turn it back for normal driving. Love it.
I had ad to really stand on the pedal to get the QJ secondary's open. All QJ's have a simple spring adjustment to determine when the secondaries open. However, you only want them during passing situations, or moments when you need an extra shot of power. Mine are set so that I can drive day in and day out without them ever opening. I wind out each gear to normal rpms, and shift. But should I wind the rpm's higher in each gear, say 500-1000 rpm higher, then the secondaries will crack open and I get a rush of power, then I shift and do it again in the next gear for better acceleration.
nothercrash
08-12-2020 05:03 PM
FERacing66
25
07-31-2004 06:08 AM
