351m water pump help
I need help on my 351m I wasn’t the one that took apart the motor so I have no idea what it was like before but I ordered a water pump and it came with two gaskets one gasket fits on the timing cover and the another on fits on the back of the water pump so is there supposed to be a plate between? And where does the alternator and power steering bracket mounts to?
Thank you for clearing that up! And do you know where the alternator and power steering mount goes? Does it bolt to the water pump
It's dark right now, so I can't take a good pic. But your alternator will go on the passenger side. Power steering pump on the driver's side.
This pic might help for the alternator.
It's from this thread:
https://www.ford-trucks.com/forums/1...l-trouble.html
Another view of alternator bracket. Note the spacer between alternator and cylinder head. And the curved adjustment arm at the bottom. Now look at the right side of the water pump. See the two unused bolt holes on the far right? That's where the power steering pump bracket bolts go.
Power steering pump and bracket. You can see how those two bolts attach. Note the spacer between the bracket and the cylinder head.
Thanks, Celtic!
77ford250, It's too bad the guy that disassembled that, didn't do it in a more organized manner. You probably noticed all my bolts are numbered. I always take several photographs, and bag and mark things as I disassemble. And especially for the front dress, I draw a diagram with numbers that correspond to the bolt numbers. I hope you're not having too much trouble with all those different length bolts. And if you haven't figured it out already, some of those bolts go into the water jacket. You need to use some sealant on those threads, or you'll likely have leaks.
Post 12:
https://www.ford-trucks.com/forums/5...-location.html
Should be the same for your motor.
Ruckin69
05-19-2019 01:56 PM
72CC428
09-26-2016 05:50 PM
thunderbolt61
09-28-2014 03:53 PM
