Engine perch help please!
Old 06-16-2020 | 12:35 PM
48kenworth's Avatar
48kenworth
I am putting together a 79 f250 4x4 chassis to set my 78 body and engine in. I can not find 77 1/2-79 6cylinder engine perches for the 4x4 chassis. Is there any other perch that will work or Will work with some minor fabrication? Does somebody have the correct perches sitting on a forgotten shelf somewhere they would sell? Will FE perches from a highboy work? Im really trying to not have to fab perches from scratch.
Old 06-16-2020 | 06:15 PM
72rtchallenger's Avatar
72rtchallenger
https://www.fordification.com/tech/engine-perches.htm I cant answer your question but the link may help some , good luck in your search
Old 06-16-2020 | 06:24 PM
48kenworth's Avatar
48kenworth
Yea I saw that, its mostly for 2wd stuff.
Old 06-17-2020 | 12:38 PM
speedfreak78's Avatar
speedfreak78
I've never heard of a 77.5-79 f250 4x4 300. That's pretty cool. You should turbo it. I always thought the base engine was a 351M those years.
Old 06-17-2020 | 02:03 PM
48kenworth's Avatar
48kenworth
Its already pretty hot N/A. 300 was definitely the base engine
Old 06-17-2020 | 09:43 PM
fordrealdrive's Avatar
fordrealdrive
Deleted...
Old 06-17-2020 | 10:29 PM
48kenworth's Avatar
48kenworth
Originally Posted by fordrealdrive
4x4 Engine Perch Part Numbers
(Bracket, Engine Front Support)
'77-'79 F250
Left: D7TZ-6029-E
Right: D7TZ-6028-E
This is from the link
72rtchallenger posted.
Yes sir, but i know the upper frame flange bolt spacing is different between highboys and lowboys so that in itself changes the part number. Drilling one hole is not an issue for me. I just need a tower that will locate the engine properly on the chassis before the body is mounted. Im hoping to find a voice of experience in my odd situation. My research says 73-77 highboy 300/FE towers will work fine but im not 100% positive.
Old 06-17-2020 | 10:48 PM
fordrealdrive
Deleted....
Old 06-18-2020 | 07:03 AM
48kenworth's Avatar
48kenworth
Yes sir they are different. But the question here is specifically what is physically different between lowboy towers and highboy towers?
jbarefoot
Engine Swaps
05-03-2011 01:22 PM
havi
13
02-26-2011 07:54 AM
bliss1
09-06-2008 08:58 PM
bigfootsurfin
07-10-2004 12:25 AM
Goober
06-15-2000 12:32 PM
Quick Reply: Engine perch help please!
