1972 f250 4x4 build
Old 02-22-2022, 07:21 PM
JEFFFAFA's Avatar
JEFFFAFA
JEFFFAFA is offline
Nice progress.
  #317
Old 02-26-2022, 07:06 PM
1browski's Avatar
1browski
1browski is offline
My converted ammeter to voltmeter just showed up today from Rocketman(RCCI).
I left the original face on it. Cleaned my other gauges up and put the instrument panel back together.
I was going to get upper and lower valance on and the grille today. Then as I pulled out baggies of hardware, it was too dirty. I have it all soaking in vinegar for today. I will get it all on tomorrow. I have new seals for my heater as well. Might do that later tonight.
  #318
Old 02-28-2022, 09:02 PM
1browski's Avatar
1browski
1browski is offline
Just need to get the hood on to protect the wiring that is about to happen, since it is outside.
I used my 71/72 grille for now because I have 71 inserts for it. I am planning on using my 70 grille later. I like the look of those better.
Forgot how many damn fender bolts go on the front end of these trucks. Put the wiper assembly/motor back in also.
  #319
Old 03-05-2022, 12:06 PM
1browski's Avatar
1browski
1browski is offline
Firewall cover came in yesterday and looks good. Havent put it under dash yet to check fit. When I put my hood hinges on the truck and bolted them down, found a stripped nut. Cant remember what they are called but the rectangular ones that are welded in like on the core support. I had another one laying around so I tacked it to the other one. If the whole front end wasnt on, I would have replaced it properly. I put the hood on too. My passenger side hinge seems a little off though. When I put the hood down, the back doesnt go down all the way, then it can be pushed down and look right. I have to check and see if I have another hinge off parts truck, I cant remember.
  #320
Old 03-05-2022, 02:13 PM
cbrown9064's Avatar
cbrown9064
cbrown9064 is offline
Really good progress! Jealous, as my cab is still waiting on the blaster.
Love everything you have done. Excellent!
  #321
Old 03-07-2022, 05:44 PM
1browski's Avatar
1browski
1browski is offline
Needed some replacement electrical things that I broke on my power distribution box from the JY yesterday. Not sure how long it was there but a 71 f250 had showed up. There wasnt much of anything that was good on it except hood hinges and the solid rear window that I need eventually. I thought I might need a passenger hood hinge, so I got them both as well. There was a 64 f600, I think, sitting there too that was pretty stripped.
  #322
Old 03-07-2022, 06:04 PM
nutter3's Avatar
nutter3
nutter3 is online now
What brand firewall insulator is that? I just got one for my 75 from Quiteride, but haven't gotten my hands on it yet to see the fit.
truck is looking really good. On your hood hinges, are they lubricated really good?
  #323
Old 03-07-2022, 09:40 PM
1browski's Avatar
1browski
1browski is offline
My firewall pad and my last batch of seals that I got came from https://chuckstrucksllc.com/. Everything has looked good and worked well. Yes, the hinges did get lubricated good with some thin stuff from work that is called Super Slick Slick Stuff. Yes that is really the name. I havent messed with the hood much in the last couple days but it might be getting better, not sure yet. I opened and closed it a couple times and it wasnt hanging up as much. I do have another set of hinges if I need them though.
The following users liked this post:
  #324
Old 03-08-2022, 02:06 PM
fe390pc's Avatar
fe390pc
fe390pc is offline
If you get a chance to post a pic of the firewall cover in place I would appreciate it.
  #325
Old 03-08-2022, 03:43 PM
1browski's Avatar
1browski
1browski is offline
Will do, it did not come with the push in hardware to mount it. I will find some this weekend.
  #326
Old 03-09-2022, 07:10 AM
fe390pc's Avatar
fe390pc
fe390pc is offline
Thanks sir!
  #327
Old 03-09-2022, 07:37 PM
nutter3's Avatar
nutter3
Thanks, I'd never even heard of Chuckstruck, and I've been on here for years. They appear to have a lot of parts.
  #328
Old 03-13-2022, 07:59 PM
1browski's Avatar
1browski
1browski is offline
I went to put the firewall cover in and had to pull wiring harness back out. Then cut the insulation out of the cut outs. I had to trim two small spots to make it fit but other than that, it fit well.
These pics, I was still fitting it. I had to get the clutch/brake pedal assembly in and also the gas pedal assembly. I did it all bass ackwards of course and it took forever. I think I had the clutch/brake on three times and off two. I will get a better pic for you fe390pc.
  #329
Old 03-13-2022, 08:18 PM
1browski's Avatar
1browski
1browski is offline
  #330
Old 03-14-2022, 09:29 AM
fe390pc's Avatar
fe390pc
fe390pc is offline
The fit looks really good. I appreciate the pictures sir!
Quick Reply: 1972 f250 4x4 build
