2020 F250 Tire pressure and Forscan help
Hey guys I just finished installing a Carli leveling kit on my F250 with new wheels and tires. Carli recommends dropping the PSI in the tires for a significantly better ride. I didn’t think that was true until I did it and it made a huge difference in the ride. Now my tire pressure light is on and I would like to get that corrected. I was looking for guidance on Forscan and can I update the tire pressure? Please tell me what I need to get this done and feel free to talk to like you would your red headed step child because I honestly no anything about Forscan.
What are your current values at these addresses ?
726-10-01 xxxx xxxx **xx
726-10-02 **xx xxxx xxxx
Yes, you absolutely can use Forscan to look at those values in the BCM, lines are referenced, change them to the correct codes to reflect what PSI you want to alarm at. I am set to 55 psi all the way around on my truck. Ussually run about 58 PSI Cold. They go up to about 65 running down the road at 70 mph, depending on outside temp. I air up to 60 front, 70 psi rear towing/loaded. Dongle for Bluetooth into the module from a laptop with Forescan is cheap. Ford could do it in their IDS same way, but they will not modify due to litigation/legal. Find the thread with the 2020 year Forecan spreadsheet.
Then you can do a bunch of other mods too.
According to the spreadsheet in this Thread it looks like the values for TPMS are still pending, so maybe keep an eye on that thread for a bit. I just wanted to say nice truck and ask what size tires those are. I am thinking about raising up my running boards like yours as well.
then I can update the spreadsheet
I set the threshold to 45 psi all the way around, currently tires are at 50.
I apologize for the late response. According to Carli I’m supposed to be at 45 in the front and 40 in the rear. That’s what I set it at. Also what OBDII connector do you recommend? I don’t have one yet
I bought this one based on recommendations in different thread, it's cheap but works just fine:
Tire pressure warning can be set, as others have pointed out already. But first, you will need to download Forscan, then register it so you can use it for free. Also download the spreadsheet. Maybe you will see other mods you would like to make. Watch some YT videos if you are not sure.
https://www.amazon.com/dp/B01N18TOFB/ref=sspa_dk_detail_1?psc=1&pd_rd_i=B01N18TOFB&pd_rd_w=tWMpZ&pf_rd_p=48d372c1-f7e1-4b8b-9d02-4bd86f5158c5&pd_rd_wg=AgJ3g&pf_rd_r=TE58RA6WH6BAKGHE5ZH0&pd_rd_r=3572078c-c147-4a84-ad1c-60176f5a76f5&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUEyWFg1OThFRjA2VTVNJmVuY3J5cHRlZElkPUEwMzk4OTE0MzlZMFZKWU9BUktFSiZlbmNyeXB0ZWRBZElkPUEwMzY2NzIySTFaNFI4TEQ3NlQmd2lkZ2V0TmFtZT1zcF9kZXRhaWwmYWN0aW9uPWNsaWNrUmVkaXJlY3QmZG9Ob3RMb2dDbGljaz10cnVl
I would get a large mug of java With some time and go through and read the ForScan threads. You don’t have to read all the posts. But LivItUp has a fantastic tutorial and adapter recommendations. I would start there
I bought this one. I use Forscan via bluetooth with a PC laptop and I can use my iPhone as a gauge and monitor while driving down the road.
OBDLink MX+
OBDLink MX+
I have same for my 2017 in signature though. I think 45 psi is too low, when I do the "chalk test" at 58 front and 58 rear on my CC LB Diesel, I have all the full width of my 295/65*18 Good Year Duratrac's touching the ground BUt I have a heavy toolbox and 35 gallon auxilliary fuel tank in the box and a fair bit of stuff under the back seat....
The OP's wider sidewall maybe more forgiving in that a wider sidewall can flex more, perhaps that tire weight charts will be ok that low, I just don't know.
Finally Fix TPMS Values
thanks for the large amount of help at the 2 forums, great folks here.
Wildcat Fords
06-24-2020 05:46 AM
one_wicked_element
1999 to 2016 Super Duty
03-04-2008 09:13 PM
