How I do the in-tank and pre-pump mods (aka hutch and harpoon mods)
#76
#77
I went with the -02. I spoke to someone from racorstore.com and he sent me the literature. They are identical except the -01 is 1/2” ports and the -02 is 3/8” ports.
#78
#79
I have not fitted the filter yet so can't comment much more
#80
You’ll need 3/8” MNPT to 3/8” barb to go to tank and 3/8” MNPT to 5/16” barb to go to pump. (McMaster Carr is a good source)
I like the push-lock fittings (no clamps = cleeeeaaaaner).
https://www.mcmaster.com/push-lock-hose-fittings/
#81
Yes, (2) plugs are included.
No problem finding the single fittings in the regular barb style (just looking for single fittings) that fit directly to the Racor without adding additional adaptors (additional leak points).
#83
#84
In that topic, I recommend paint or powder coat RACOR base. It will oxidize and look like crap after it’s been exposed to salt/etc.
#85
My ocd kicked in. I had originally ordered the Racor, but cancelled the order for now. I go back and forth which setup I want to go with, but now I'm leaning towards Jason's Wix filter and complete setup for the save in cost. I have a lot of things that I need to do to my truck. So saving some money to put towards other things would be nice. Plus less prep work. But then again, I'll probably change my mind 3 different times.....lol
#88
I ordered mine from Amazon
Gates 27341 Barricade MPI Fuel Line Hose https://www.amazon.com/dp/B0053OSBCC..._bTraFbH8MW2J5
and
Gates 27348 Barricade MPI Fuel Line Hose https://www.amazon.com/dp/B0058XDL0K..._6UraFbCSYEAYQ
I ordered stainless fuel injection clamps from Amazon as well.
and
#89
#90
I know alot of people have had success with the wix but I just could not keep the air bubbles from flowing so I went with the racor setup. If you are on a budget then you could give the wix a try..... but if you can swing it, get the Racor.......i put the racor on both my trucks and very glad I did, but the wix will do the same thing
30R9 hose and fuel injection hose clamps are important details.
I prefer the simplicity of the WIX. It’s also economical, but it’s cleeeeaaaaan and easy. Most people never need to change the filter.
