2020-2022 Super Duty FORScan Spreadsheet
#1576
I've got a follow up question though, I noticed the DRL's only come on while in gear. Is that new (something I messed up) or normal? I neglected to check before making changes haha
#1577
My 22 is like that, DRLs only come on in gear.
The following users liked this post:
#1578
I have a 2022 F-250 Super Duty, trying to get the Power Points (DC plug in cabin) to stay hot for 12 hours. I don't see that on the 2020+ Super Duty spreadsheet. When I look at the F-150 sheet they indicate it should be BCM 726-39-01 but that doesn't look right on my as-built. 726-57-01 looks like it has the right hex value for the 75minute default. I think I'll give it a try and let you know if it works in case somebody wants to add it to the new SuperDuty spreadsheet.
#1579
#1580
You are correct 726-57-01 xxxx is the correct line for PowerPoint max time
I will add it to the spreadsheet
ZooDad
#1584
Hello all, dipping my toes in this Forscan pool.
I've got Forscan, got a license, connected to my truck and made backups of each module listed as "As Built".
Have 2 questions:
- when you make a change and Write it to the module, there's a prompt to cycle the key Off/On. What is the order of operations to do that? => 1) when prompted, click OK, then cycle the key Off/On, then stop the module - 2) when prompted, click OK, then stop the module, then cycle the key Off/On ?
- ZooDad's spreadsheet lists Adds Average Speed to Trip/Fuel Menu. Does this mod work on an XLT with Sync3 and the below cluster?
Have 2 questions:
#1585
Good Evening,
After working with ZooDad. I was able to get the running lights off with the DRL's.
Any of you Canadians that have a 2021 that you want to shut the running light that automatically come on with the DRL's do the following.
BdyCm-as built 726-38-01 xxxx xxxx x*xx 0=disable 1=enable
Thanks again for all the help.
Paul
Paul
#1586
I recently bought a 22 platinum. Truck is Canadian as well. When I put the truck in gear the c lights up front, mirror lights and cab lights on the roof and the tails come on. Is that what you’re referring to as running lights? All I want to come on are the c lights up front.. thanks in advance!
ZooDad
#1589
#1590
