2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
2020-2022 Super Duty FORScan Spreadsheet
Old 05-26-2022 | 08:54 AM
ZooDad's Avatar
ZooDad
Retired guy fix’n stuff
Originally Posted by ~erik~
Maybe I'm blind but I'm not seeing how to turn off the driver's seat belt reminder chime in Zoodad's great spreadsheet. Is it the same as what I did on my 2017 F250?
Thanks for your support!
Try this in the IPC
720-01-01 xxxx xx2x xx—
Let me know if it works. I’ll add it to the spreadsheet
ZooDad
  #1562
Old 05-26-2022 | 10:39 AM
~erik~'s Avatar
~erik~
Originally Posted by ZooDad
Try this in the IPC
ZooDad
Thanks for the quick reply. Yes, that worked fine, thanks. I also added the temps on gauges, Increased the turn signal flash count, and put the fog lights in bambi mode. Slowly getting this new truck to be like my 2017 F250.
Thanks again!
  #1563
Old 05-26-2022 | 05:03 PM
ZooDad's Avatar
ZooDad
Thanks again!
Thanks for letting me know.
ZooDad
  #1564
Old 05-26-2022 | 08:43 PM
1Legacy's Avatar
1Legacy
question. I just installed new tires and rims on my 22 f250. I wanted to change the TPMS setting so I took the original settings
726-10-01 = 0201-0000-3C7D
726-10-02 = 4100-0078-00F8
I wanted my front TPMS set to 50 PSI and my rear set to 40PSI. I converted to HEX 32 for the front and 28 for the rear. Below is what I changed
726-10-01 = 0201-0000-327D
726-10-02 = 2800-0078-00F8
Now my TPMS is not being picked up. I tried to relearn the new tires by swapping the engine off and back on in accessories then turn the hazards on and off 3 times and then letting air out of the front tire. Still, the system never recognizes the TPMS and double honks which indicates the truck didn't pick up the sensor according to the manual. Any advice?
  #1565
jollyrogr's Avatar
jollyrogr
Try this in the IPC
ZooDad
It's also possible to turn off the seatbelt minder without Forscan. It tells you how in the owners manual.
The following users liked this post:
  #1566
Old 05-28-2022 | 10:36 AM
ZooDad's Avatar
ZooDad
Someone with a 22
I believe I have found the Nav in motion for Sync 4.
Can someone test for me.
Please shoot me a PM for info.
Thanks
ZooDad
  #1567
Old 05-28-2022 | 06:17 PM
1Legacy's Avatar
1Legacy
Thanks
ZooDad
I should be able to try it tomorrow. If you want to send me the blocks to change.
  #1568
Old 05-29-2022 | 09:17 AM
ZooDad's Avatar
ZooDad
Thanks
ZooDad
Well no joy for Nav in Motion so far. I will continue to look and see what I can find.
ZooDad
  #1569
Old 06-06-2022 | 10:09 PM
reseehc_99's Avatar
reseehc_99
I read the whole thread and didn't see it mentioned anywhere. Is there a way to disable the "Check rear seat for occupants" warning when you turn the truck off? That is the last warning/chime I have left.
My truck is a 22 F-350 XL STX Sync 3
  #1570
Old 06-06-2022 | 11:35 PM
rbaldus's Avatar
rbaldus
Trailering
It's in the advanced settings on your information cluster.
  #1571
Old 06-07-2022 | 06:40 AM
reseehc_99's Avatar
reseehc_99
I guess I should have just
The toggle for this function (for vehicles with Sync 3) is on the touchscreen in the center stack. Settings > Vehicle > Rear Occupant Alert
  #1572
Old 06-07-2022 | 08:51 AM
Darryl W.'s Avatar
Darryl W.
4wd High
Throttle
Just got the Banks Pedal Monster for my 2020 6.7, what a difference it makes.
  #1573
Old 06-16-2022 | 11:56 AM
Rob89's Avatar
Rob89
I want to do the bright C rings, is that the “drl full brightness with headlights” line item?
  #1574
Old 06-19-2022 | 07:38 AM
ToMang07's Avatar
ToMang07
Ok, so after finally getting Forscan to work, I followed the procedure for the IPC, BCM, DDM, and PDM modules for Global Open/Close. Only the front 2 windows will open, which is fine, (Although all 4 should as far as I can tell) however only the Driver window will close.
Anyone ran into this or any idea on a fix?
Everything else worked as far as I can tell. (Bambi mode, seatbelt chime, etc.)
  #1575
Old 06-19-2022 | 08:04 AM
chadstickpoindexter's Avatar
chadstickpoindexter
Only the front driver and passenger open and close on on mine. Unlock=open. Lock=close. Both driver and passenger open and close at the same time.
Quick Reply: 2020-2022 Super Duty FORScan Spreadsheet
