T-5 Manual Transmission
I have read where people have used the T-5 5 speed overdrive transmission in their trucks and other hotrods. I have a World Class T-5 out of an early 90's Mustang and planned on using it but I know the shifter location is a little far back and is very close to the seat when using a bench seat. I recently saw a T-5 out of a 2005-2010 V6 Mustang that appears to be much shorter and looks like it would bolt up to the bell housing I have for the 351W.
Has anyone used one of these transmissions in a build?
Also, in the 2005-2010 mustang the shifter does not bolt to the top of the transmission, it is remotely placed behind the transmission. Can the top plat be removed and adapted to use a shifter bolted to the top of the transmission? If so, I think this would be the ideal setup as it looks like the shifter would still come up through the trans cover in the floorboard.
Thanks for any inputs on this setup!
Jeff
Jeff
In my 54 F100 I used a T-5 from a 91 Mustang on a 5.0 from a 98 Explorer that was previously an automatic. I used the bell housing that came with the transmission and a Tilton hydraulic clutch.
I was going to find a S10 tail piece to get the shifter forward. Before I bought the engine and in anticipation of how things might fit, I removed the bench seat and installed bucket seats and a console
that sits a little behind the front of the seats because I didn't know exactly how the shifter would fit. As it turned out, everything fit pretty good with the shifter in the stock position. If you are keeping
the bench seat, then a S10 tail piece would be best.
markthompson999
04-22-2012 05:32 PM
zonkola
03-20-2003 01:48 AM
