We can manually lock the hubs with the plow on and the 4x will not work. If the plow is off, the 4x works. Checking with the driver on your second question. He told me the tries to plow with the truck and it "pops out" of 4x. Thank you for your response.
may want to check it yourself just in case the driver is inexperienced and doesn’t really know.
Put it in 4hi, raise the plow, and drive slowly on dry pavement doing easy turns to see if you feel the front wheels binding (which means the 4wd is engaged).
